So, how do I make her tight again??
Old Jul 13, 2010 | 10:15 PM
Ever Hernandez's Avatar
Rx8_4eVeR
I'm talking about the alternator belt and air conditioning compressor belt. Taking them off wasn't a big deal, but half way through the job I got stuck on stupid. I had bolts B & C all the way up and the belt was still loose, any ideas? The process sounds simple enough in theory, so what am I missing?
Attached Thumbnails So, how do I make her tight again??-bhj0110w004a.png   So, how do I make her tight again??-bhj0110w005a2.png
Old Jul 13, 2010 | 10:31 PM
maskedferret's Avatar
Oooh, shiny!
In the first image for the alternator belt, bolt B is the locking bolt; leave it loose until you have everything properly tightened. Tighten the belt by screwing in (clockwise) bolt C until deemed tight enough. Once this is done, torque bolt B to spec. Afterwards, if bolt A was loosened at all it should be re-tightened. Loosening it would have only made it easier to move the alternator.
In the second image for the AC belt, bolt A is the locking bolt. Screw in bolt B (clockwise) until the belt is appropriately tight. After this, torque bolt A to spec.
Old Jul 13, 2010 | 11:42 PM
Got them on the pulleys
( sorry man..couldn't resist )
Old Jul 14, 2010 | 12:38 AM
Hell ... I thought he needed a sowing kit.
Old Jul 14, 2010 | 12:48 AM
laythor's Avatar
I zoom therefore I am.
why would he be working on his car in a field why he was planting seeds?
Old Jul 14, 2010 | 12:50 AM
Oooh, shiny!
I think he meant "sewing", and taking that in the ... lewd manner ... I think he meant, it freaked me out a bit.
Pardon me if I ruin the double entendre jokes. :P
Old Jul 14, 2010 | 01:23 PM
2tone's Avatar
The RX-8 is missed
i thought this thread was going to be epic judging by the title!!
that said, this is quite helpful b/c i may need to do this soon! i've never done ANY engine work...it changing these belts something average joe can do at home so i don't have to take my car in??
Old Jul 14, 2010 | 01:47 PM
Oooh, shiny!
Yes; it's fairly easy enough to do with a socket wrench. The AC locking bolt may require a breaker bar.
Old Jul 14, 2010 | 08:14 PM
Rx8_4eVeR
Some other people would say, "drop lemon juice in there"
Old Jul 18, 2010 | 12:18 AM
Rx8_4eVeR
Apparently if you have after market pulley like I do, you need smaller belts than OEM. This is what I got at first but I needed a smaller belt for the AC.
Loosen the locking bolt, just enough.
Then the alternator, again, just enough
Then drop the alternator unscrewing the tension bolt.
YOu may want to remove the battery to have more room to work with. I didn't have to.
Used a 17mm off-set ratcheting wrench to loosen the AC tensioner pulley.
and a 10mm socket with extensions for the bolt
And these are the items I used. Remember, I needed a smaller AC belt because I have aftermarket pulleys.
RevMeHarder
Jun 1, 2026 02:30 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
DVerdeyen
Sep 13, 2015 11:19 AM
