Making Sure Im Not Missing Anything, Springs and Shocks
Hey guys, just wanted to check and make sure I have everything i need regarding springs and shocks:
One set of these : http://assaultech.com/tein/tein_spri...h/g-50214.aspx
two orders of front : http://assaultech.com/koni/koni_shoc...s/g-52201.aspx
two orders of rear : http://assaultech.com/koni/koni_shoc...s/g-52201.aspx
As you can suspect I'm looking to set my ride up with koni yellows w/ tein s-tech springs. First time suspension installer so just making sure i didn't forget something important.
(hope AT doesn't mind me using their links)
i'm just going to toss this out there. i have a set of used koni yellows and tein springs that i never got around to installing and have changed my mind on the direction i am going. i don't know how many miles are on them but if you want some pretty cheap, i'm in CT and have a set. i bought them from a forum member and figured that i'd use them for as long as they had life and rebuild them if they needed to down the road and still end up ahead but will now wait for my OEMs to go and then will probably look at some dspecs.
EDIT: these konis have been sold. i'm editing this post because i have had a few inquiries on them but the konis are long since gone.
So if the Konis don't have adjuster cables then get the D-specs; The adjuster cable for D-Spec is about $30
I never adjusted my Koni's one time. I haven't adjusted my coilovers yet either (I really need to though lol). Just because you have a million settings doesn't mean you are going to use them. Moral of the story: Don't base the purchase just on ease of adjustability. Check and see if you can ride in cars with both types of shocks and then compare.
Well, spent some time digging through the billion threads about koni vs tokiko d-spec ... looks like my decision is going to be the tokiko since it will give me the freedom of adjusting and will give me a better sense when installing the shocks knowing that i can always fix mismatched settings even when the shocks are installed.
Now to decide on the method to use lol ... never installed springs before. Found a ton of threads, some that remove ball joints and some that dont ..... the one that doesn't remove balljoints looks like it is a lot more involved and more advanced though.
Thanks again for the tips guys, i really appreciate it!!
If you just do street driving tokico is a very nice shock, but if you plan to track the car later I will buy Koni.
I took off the camber adjustment blot on rear to take out my shock, it is way easier. you need a alignment anyway after the installation..
http://www.hi-impact.org/ryang/modif...ock_front.html
http://www.hi-impact.org/ryang/modif...hock_rear.html
which make it look easy to do
actually, i'm pretty sure the S1 and S2 have different setups. I remember someone selling konis for the S2 so I'd assume they are different.
Guess that means that i can spend the money on the GreddySE i want instead until the suspension kits come out heh.
Thanks again for all the advice and tips guys, hopefully things get moving for the S2 and I will have some new pics and 'thank yous' to show.
WingleBeast
22
May 23, 2016 09:22 PM
ColeParkerrr
Sep 15, 2015 07:30 PM
{ FS } 13b renny auto fresh rebuild
Andres Gonzalez Morales
Aug 22, 2015 03:07 PM
Touge
Canada Forum
Aug 13, 2015 04:48 AM
ahyuo121
Aug 3, 2015 01:52 AM
