Sensor on control arm on front driver's side?
Old Jul 10, 2010 | 03:42 PM
Munchy's Avatar
RX n00b
There's some sort of sensor or something that's bolted to the suspension arm on the front driver's side...
Anyone know what it does?
(I snapped the bolt so it's tie wrapped in place, just want to check how urgent it is to fix it)
Old Jul 10, 2010 | 03:57 PM
Headlight level sensor.....that little sucker is expensive..so look for a used one..or try and fix it
Old Jul 10, 2010 | 04:27 PM
Munchy's Avatar
RX n00b
While installing my springs, we accidently snapped the head of the bolt so the sensor isn't damaged or anything. It's just attached to the arm with a tie wrap at the moment while my buddy finds an extractor.
The fact that it's not on solid and a bit shaky, does that affect anything?
Old Jul 10, 2010 | 05:18 PM
It might make your headlights strange...but shouldn't do much else
If it doesn't work properly after..the specs are in the FSM to test it with 4.5V power source to check the output PM me if you can't find it when you need it
vapor2
Oct 8, 2015 02:08 PM
SayDfuse
Aug 3, 2015 10:41 PM
MarkX
Jul 31, 2015 07:50 AM
amshaw
Jul 27, 2015 08:41 PM
