Group Buy Center Approved group buys ONLY. To become an approved group buy vendor - go here:
https://www.rx8club.com/payments.php
The GOODbox
Rating: Thread Rating: 2 votes, 1.00 average.
Old Jul 10, 2010 | 11:42 AM
  #26
pieter3d's Avatar
Originally Posted by 9krpmrx8
Hmmmm, If I give the manufacture of the sending units/gauges can you figure it out and sell as a package? To have all the data currently and oil pressure and oil temp would be perfect.
No I would need to measure the voltage on your car while it is running. If you think you can't figure it out, your best bet is to ask someone you know who is more familiar with this kind of stuff
Old Jul 10, 2010 | 11:44 AM
  #27
Yeah, I will have to find a real electronics guy locally. Maybe I will see if the BHR crew can figure it out, I'm probably gonna roll out that way soon enough.
Old Jul 10, 2010 | 12:31 PM
  #28
ShellDude's Avatar
weeeeeeeeee
radioshack multimeter ftw 9k...
Old Jul 10, 2010 | 12:34 PM
  #29
TX
I will look into this and see what I can figure out.
Old Jul 10, 2010 | 04:27 PM
  #30
deadphoenix52's Avatar
meh.
paid! cant wait
Old Jul 10, 2010 | 04:50 PM
  #31
meh.
Originally Posted by laythor
tempted.. but unsure if it'll work with my corksport dash kit. all the factory harnesses are still there..... hmmmm
i also have the corksport. i bit. if you want ill let you know
since the display reads on startup im fairly certain it will work
Old Jul 10, 2010 | 04:56 PM
  #32
WAR CRUNK's Avatar
U.S ARMY 11B
im in give me a day to get the cash
Old Jul 10, 2010 | 05:36 PM
  #33
melstar57's Avatar
Hello,
You mentioned that these weren't compatible for the mazda3's - does this include the speed3's too?
Is it because you dont have the instructions for the MS3's or was there an actual wiring problem??
I really want to jump on this and pick one up if it will work.
Old Jul 10, 2010 | 05:38 PM
  #34
pieter3d's Avatar
Originally Posted by melstar57
Hello,
No, it will not work. Although the 3 uses the same LCD, the display module communicates with the rest of the car completely differently. I would have to design a different circuit board to work with the 3 and/or 6.
Old Jul 10, 2010 | 05:41 PM
  #35
melstar57's Avatar
booo....
so when can we expect the new circuit board to be released
Old Jul 10, 2010 | 05:48 PM
  #36
laythor's Avatar
I zoom therefore I am.
lol.. sent you a PM.. then immediatly said "f-it" and sent my paypal in. This is gonna be great if it works.. otherwise i'll have a never used goodbox for sale for 400 bucks after these all sell out
i kid, i kid.
Old Jul 10, 2010 | 10:44 PM
  #37
Ryan2008's Avatar
Registered Paratrooper
not cool...
Thanks for the PM pieter3d, will have funds soon! Great product as I said before!
In the meantime, I know he has very detailed install instructions, but if anyone can find any tricks or anything while installing, definitely post up!
Ryan
Old Jul 11, 2010 | 07:19 AM
  #38
HiFlite999's Avatar
Originally Posted by pieter3d
It really isn't too bad. You just have to know how the voltage from the sensor maps to the temp/pressure. So if you have 2.3Volts from the oil pressure sensor, what is the pressure that that represents? You would use the gauge you have now to determine this.
Standard sensors are simply variable resisitors. They vary in response to what they are measuring. (My oil pressure sensor varies from 3 to ~160 ohms as the pressure varies from 0-10 bar if I'm remembering right.) A sensor by itself doesn't produce a voltage, that has to come from somewhere else. (Volts = Current x Resistance). One has to either supply a constant voltage and measure a change in current, or a constant current and measure the change in voltage. Classic cheap gauges are basically am(p)meters which use the ~14.7 constant voltage from the battery to measure the changing current caused by the variable resistance of the sensor. In other words, there is no way to tap a variable voltage signal for input to the Goodbox from a "classic" cheap gauge set.
Do "modern" cheap gauges work differently? IE, by internally incorporating a constant-current power supply to produce a voltage that varies with the changing resistance of the sensor? If that's the case, then tapping the voltage line of the gauge will work if the signal range falls in the 0-5V range. But then, having the gauge installed is required to get the Goodbox signal, which kinds defeats the purpose of having a Goodbox in the first place.
It seems to me then to get an oil pressure or temp signal without having a gauge installed either requires a little independant constant-current power supply to run the sensor circuit, or using battery voltage together with a little ammeter with an appropriate voltage output.
Am I thinking right or am I stuck in the Edison-era?
(Payment sent by the way!)
Old Jul 11, 2010 | 08:07 AM
  #39
paulmasoner's Avatar
Asshole for hire
HiFlight, all you gotta do is look
this is just a random pressure sensor i looked up
http://www.senzors.com/us/products/h...ts/hiprecision
Pressure ranges
Any from 0-300 psi to 0-3,000 psi
Overpressure (safe overload pressure, proof pressure)
1.5x rated pressure
Operating temperature range
-40 to 125°C (-22°F to 260°F)
Accuracy
0.05%FS typ.
Supply
10-28VDC (constant voltage)
Output signal
4-20mA, 0-1V, 0-2.5V, 0-5V, 0-10V
Pressure port
Many choices available
Electrical termination
Wetted parts
316L Stainless Steel
if you know what you are looking for, you can put damn near any "gauge" you want on this thing... 0-5V output is so damn common
Old Jul 11, 2010 | 10:53 AM
  #40
meh.
did you ever add the CEL code feature?
Old Jul 11, 2010 | 12:04 PM
  #41
zoom44's Avatar
page 8 of the instruction manual
Old Jul 11, 2010 | 12:17 PM
  #42
meh.
lol. since there werent pictures i didnt read it....
Old Jul 11, 2010 | 12:19 PM
  #43
Asshole for hire
then this is not a mod for you...
Old Jul 11, 2010 | 12:22 PM
  #44
meh.
haha. nah, ill read it all once i get the unit in hand
Old Jul 11, 2010 | 01:08 PM
  #45
zoom44's Avatar
paid!
Old Jul 11, 2010 | 01:56 PM
  #46
HiFlite999's Avatar
Good find. What I was trying to point out is there's a bit of a disconnect in the discussion. Page 8 and on in the instruction manual tells what to do with a 0-5V signal, not how to get that signal. What you can't do is wire the goodbox to a standard sensor, at least the 3 different versions I've gotten from summit, glowshift and ebay; they all vary resistance. To make that kind of sensor work, you have to add some electronic stuff. Or, a much better suggestion, use a sensor with a native 0-5v output for the Goodbox as you showed, but then a standard gauge won't work with that. Getting both to work, like 9krpm was talking about, would require some cleverness.
Old Jul 11, 2010 | 02:03 PM
  #47
Asshole for hire
oh, i missed the part about making it work with regular gauges as well.... i feel stupid now....
yeah that will take some doing. it wouldnt be hard from an electrical engineer point of view, but prolly more than most people would want to DIY
Old Jul 11, 2010 | 05:59 PM
  #48
dondo's Avatar
100% baller (finally!)
it works as advertised!
Old Jul 11, 2010 | 08:29 PM
  #49
Nice!!! Can you give me your supercharger so I can see if the boost function works?
Old Jul 11, 2010 | 08:30 PM
  #50
AusAndrew's Avatar
Well done and congrats Dondo, first installed! Also good work on quick shipping from Pieter. He's been great organising and shipping to Australia and I can't wait for it to arrive.
I'm interested in this too. I'm planning on hooking up oil temp, but not sure exactly what will work with it, given that I don't already have a gauge.
I still have a couple of weeks, while my unit flies over the ocean, to find a temp sender and sort out potential electrical issues as above.
You have already rated this thread Rating: Thread Rating: 2 votes, 1.00 average.
