Slow shift from 2nd to 3rd. Also slow into reverse.
Old Jul 8, 2010 | 08:35 PM
chonniedotcom's Avatar
Hey gang.
I have an 04 RX8 with 4 speed automatic transmission. 62,000 km. Original engine and tranny.
Car appears to be running perfect with the exception of when I upshift from 2nd to 3rd in manual mode. When I use the paddel or shift ****, it takes almost a second to make the shift from 2nd into 3rd. Other gears it is almost instant... (From 1st to second or from 3rd to 4th)
I also notice going from 1st gear, at a standstill to reverse, there is a similar delay, about a second until it engages into reverse.
It is annoying when I am getting close to redline in 2nd shifting to 3rd... if I don't "time" the shift right I will then hit the rev limiter and it does it's funky stutter...
Any ideas? Thoughts?
Thanks....
(Ya.. I know.. .I should have bought a 6 speed manual) Ha ha ha... Still might.
Thanks again.
Old Jul 11, 2010 | 10:31 AM
Nuthin?
Nobody has seen or had this type of issue???
Bummer.
Searched this forum and all over the web to no avail...
I will have to take to my mechanic then...
Thanks anyways.
Old Jul 11, 2010 | 10:53 AM
EDZRIDE's Avatar
2005 White GT
Check the fluid level. Also, wouldn't hurt to have the transmission flushed.
Old Jul 11, 2010 | 11:41 AM
BigMikeATL's Avatar
I had a similar problem with my Acura TL and had the transmission fluid flushed. After that, it ran smooth as the day I bought it.
Even though your mileage is low, if you haven't had the fluid changed that means it's 6 years old and overdue.
Old Jul 11, 2010 | 12:20 PM
zoom44's Avatar
yeah when was teh last time you checked the fluid level?
Old Jul 12, 2010 | 09:15 AM
Thanks!!!!
Just checked the fluid level a few days back... was good. Even looked a bit on the high side.
Dealer told me that it was all services before I bought it... I will clarify if they did do a tranny flush as well.
Thanks for the feedback....
Old Jul 6, 2023 | 10:23 AM
cfletcher592's Avatar
Originally Posted by chonniedotcom
Hey gang.
Thanks....
Thanks again.
i have a 05 and it’s a 4 speed as well not entirely sure what’s going on with the shifting but 2nd gear is a total nightmare for me. It’s hard to drive on and when it gets to about 5k rpm it sounds completely different. I’m going to look around in here and if I don’t find anything I’ll take to a shop
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Racingjunkie
Sep 29, 2015 05:05 PM
XianUnix
Sep 29, 2015 03:48 PM
