well i'm finally part of the club
Old Jul 8, 2010 | 06:51 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
When i was leaving work yesterday i stepped on my clutch and heard a loud pop. I knew what it was but my heart still skipped a beat. One of the crappy little spot welds finally broke. Its my own fault/being lazy for not welding it earlier. The clutch still worked to get home but felt really wierd so once i was moving I just shifted without it.
I pulled the assembly out last night to go use my girls dads welder. I got lucky that the bracket wasnt all twisted up like ive seen on here, and it went back together pretty easy. I didnt get to reinstall the pedal last night because it was late but ill take care of it after work today. Thankfully I have a couple of cars and a bike so it wasnt really a big deal just a pita.
Guys do yourself a favor as not to get stranded and take care of this if you havent allready. Its an easy fix/piece of mind. just thought I would share.
Jesse
Old Jul 8, 2010 | 08:17 AM
DarkBrew's Avatar
Extraordinary Engineering
+1 Good advice
Maybe one day you'll join the procrastinators club
Lucky for you you had access to welding equipment!
Old Jul 8, 2010 | 11:54 AM
maskedferret's Avatar
Oooh, shiny!
What year is your car?
I've visually inspected my clutch pedal and don't notice any flex @ the firewall; everything seems solid down there. I am unsure whether I really need the pedal reinforcement kit. Does anyone know at what point the clutch assembly was redesigned?
Old Jul 8, 2010 | 12:04 PM
tcole6's Avatar
I have an '04 Touring. I would assume that I am at risk for this...
I have no welding equipment. I found this bracket out there:
http://raceroots.com/index.php/produ...t-bracket.html
Says "Easy to install with basic hand tools". Anyone know how true that statement is?
Old Jul 8, 2010 | 12:26 PM
200.mph's Avatar
my car is an 04 and i checked my clutch pedal about a year ago when i read the problem. ive checked it several times since and it seemed fine but i was wrong. it only took me about 10 min. to remove with a 12mm deep socket and a 3" and 6" extention. oh yhea a pair of pliers to remove a clip that holds one of the sensor pluge in place. about 5 min. with a welder and it was better than new. if you dont have a welder you could probably pay someone like $20 to do it for you. imo it seems cheaper and probably stronger than the bracket.
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
Mazdakevin
Mar 10, 2016 12:32 PM
Junirol
Sep 22, 2015 06:02 AM
k4thomas
Aug 5, 2015 03:03 AM
