transmission oil spec help
Old Jun 30, 2010 | 09:14 PM
hmdmvp's Avatar
04 mazda rx8 automatic. how much oil does the tranny take and what kind?
Old Jul 7, 2010 | 01:07 AM
yiksing's Avatar
the giant tastetickles
Check manual if you have or download it if you haven't got it from Mazda website
Old Jul 7, 2010 | 08:02 AM
Never L8's Avatar
Bam...Right from the service manual!
AUTOMATIC TRANSMISSION FLUID (ATF) REPLACEMENT
BHE051319001W02
Warning
• A hot transmission and ATF can cause severe burns. Turn off the engine and wait until they are cool before replacing ATF.
1. Remove the oil dipstick.
2. Loosen the oil pan mounting bolts.
3. Drain the ATF into a container.
4. Remove the oil pan and gasket.
5. Eliminate the sealant dust from the bolt hole.
6. Install the oil pan and a new gasket with new bolts.
Tightening torque
7.0-9.0 N·m {72-91 kgf·cm, 63-78 in·lbf}
7. Add the specified type of ATF through the oil filler tube until ATF level reaches lower notch of dipstick.
ATF type
ATF M-III or equivalent (e.g. DexronII)
Capacity (approx. quantity)
8.7 L {9.2 US qt, 7.7 lmp qt}
8. Verify that the ATF level is in the HOT (65 °C {149 °F}) range.
• Add ATF to the specified level if necessary.
Old Jul 9, 2010 | 01:04 AM
hmdmvp's Avatar
Thank you
Old Jul 12, 2010 | 01:42 PM
Never L8's Avatar
My pleasure, man. That's what we're here for!
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Slack
Sep 5, 2015 06:42 PM
