Headlights aimed at the ground
Old Jun 28, 2010 | 09:18 AM
04winnersblue's Avatar
Hey guys, got another question for ya. I've got an 04 rx8 so therefore it has it's own motor to control the headlights right. I've heard that 05 or 06 and up had a dial to control the motor to change the aim of the lights. Anyways this is not working correctly so i can not even drive my car at night. Any suggestions or at least how i can get at it to try and adjust it?
Old Jun 28, 2010 | 09:24 AM
Lord ET's Avatar
Is that a bike rack?
it's the headlight leveling sensor on the driver side of the vehicle. Do a search for it on here...there are even stickies.
Old Jun 28, 2010 | 09:34 AM
alnielsen's Avatar
Yes, mine just started doing the same thing and I have to fix it. The control sensor is located on the rear suspension. There is a thread on how to repair the sensor.
Old Jun 28, 2010 | 10:03 AM
DarkBrew's Avatar
Extraordinary Engineering
Where are you located? The adjuster was not on NA models
is your headlight level sensor warning light on?
There are two sensors, one front, one rear.
Once that is sorted out you can adjust aim using the adjusters on the headlight housing.
The early models had a wiring connector on the sensors which allowed water infiltration. The water rots the sensor internals.
You can buy the upgraded connectors or get some goop to seal around the wire entry point on the connectors.
Old Jun 28, 2010 | 10:13 AM
alnielsen's Avatar
He appears to be in the Toronto (Newmarket?) area.
Old Jun 28, 2010 | 01:29 PM
thanks for all the help guys. and quick responses. I'm in central ontario if anyone's interested. I was wondering where the sensors are and yes my indicator light is on, but it goes away and the lights are still aimed at the ground. If someoen knows how to find/inspect the sensors that'd be great and where the adjustment is on the housing aswell. thanks for all the help
Old Jun 28, 2010 | 02:25 PM
DarkBrew's Avatar
TSB
http://www.finishlineperformance.com...8-07-1729a.pdf
You should find online manuals with a search
Sensor rebuild
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-headlight-auto-level-sensor-rebuild-aka-headlamp-leveling-131557/
Headlight aim
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-adjust-front-headlights-w-hid-option-165465/
Shankapotamus3
Mar 14, 2021 03:53 PM
hufflepuff
May 30, 2016 10:45 AM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
