Please help!
Old Jun 27, 2010 | 07:41 PM
LBrown8's Avatar
Please help!
My 8 is having a problem with the suspension it seems like, when hitting little bumps or small changes in the road the is a loud bang sounding from the rear, it seems like the shocks are bottoming out but yet the boys at pep boys says everything looks a ok, just replaced the rubber put a set of hankooks on her but still the sound is loud? can someone give an explination or even some tips?
Old Jun 27, 2010 | 11:23 PM
rotarykillz's Avatar
Rotary Freak
are your tires stock size? Any lowering? Maybe your new tires are hitting if they aren't oem size? Could also be something loose in your trunk.
I would goto someone besides pep boys though.
Old Jun 28, 2010 | 02:42 AM
rx8speeddmon's Avatar
I'd guess your tires are hitting when going over the bumps. If not that, then check your sway bar/endlinks. Other than my little bits of info, I don't have much more without a little more information from you.
