Tire Question....
Old Jun 27, 2010 | 06:07 AM
Dr.TuB's Avatar
Tire Question....
Previous owner fitted
front: 225 40 18 Dunlop SP Sport 9000
back: 225 45 18 Bridgestone Potenza RE040
would this cause any problems for me?
Old Jun 27, 2010 | 06:08 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Do you have DSC?
Old Jun 27, 2010 | 06:15 AM
Dr.TuB's Avatar
yes i do :D
Old Jun 27, 2010 | 06:49 AM
yiksing's Avatar
the giant tastetickles
The slight difference in circumference between front and rear tires would/might trigger the DSC under certain driving conditions where it normally wouldn't have.
Old Jun 27, 2010 | 08:25 AM
SayNoToPistons's Avatar
Wheels, not rims!!
^ +1. Front tire will be spinning faster. Might make DSC go "WTF is going on!? Lost of traction!"
Old Jun 27, 2010 | 01:20 PM
REDRX3RX8's Avatar
The good thing is: you probably won't get DSC when you turn and accelerate hard. That's when I get it a lot.
If you ever want to rotate those 3% smaller fronts to rear.... well just don't do it or you'll know why.
Old Jun 27, 2010 | 01:43 PM
Dr.TuB's Avatar
im not sure what you mean by if i ever want to rotate those 3% smaller fronts to rear......
Old Jun 27, 2010 | 01:52 PM
REDRX3RX8's Avatar
DR.TuB,
225/40r18 are 25.1 inches in diameter approx 830 rpm per mile
225/45r18 are 25.9 inches in diameter approx 804 rpm per mile
So the 40's roll 3% faster or more than the 45's for the same speed.
Old Jun 27, 2010 | 05:56 PM
Dr.TuB's Avatar
so if i were to replace the back with the 40s i should be okay?
Old Jun 27, 2010 | 08:49 PM
yiksing's Avatar
Yes, as long as the circumference is not beyond 3% difference, your DSC will not pop up.
Old Jun 27, 2010 | 09:48 PM
Old Rotor's Avatar
The 245X40X18 are a great upgrade.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
