Loud clunking noise in rear?
Old Jun 25, 2010 | 08:16 PM
LBrown8's Avatar
Exclamation Loud clunking noise in rear?
Today i was driving home on I-95 and each time i would hit a bump there would be a loud bang in the rear of the car, it almost sounds like shes bottoming out, theres not much in the back so its not being pressed down in any way, any ideas?
Old Jun 26, 2010 | 06:56 AM
REDRX3RX8's Avatar
Yeah, why would the rear suspension hit hard? Mine does, too. I can't even push down the rear with my 200#"s.
mine is caused by no more travel on the rear swaybar endlinks. I never thought a swaybar could bind, but if you look, you might see that the rear bar can't go up anymore even when it's sitting still.
I'm gonna take my stock ones off and shorten about 3/4inch when it gets a little cooler.
Old Jun 26, 2010 | 07:28 AM
DarkBrew's Avatar
Extraordinary Engineering
If your sway bar links are binding then the bar is probably on upside down. Check the online manuals...
If your RX-8 is a 2004 then the rear suspension is probably weak. Mine was like that but I upgraded...
Old Jun 27, 2010 | 12:31 PM
REDRX3RX8's Avatar
Darkbrew,
Yeah, I always thought sway bars wouldn't bind when the car is lowered, but Mazda designed them so as the car bottoms out on a bump or is twisted going across driveways, the bars quit working.
Other RX8club guys have mentioned the endlinks binding, and it took me 2 years of tracking to figure it out myself. I think I could disconnect the rear endlinks and it would work better just like some guys have suggested. I'll get that chance when they're off being shortened.
Somehow my new 2007 gt was lowered with ENKEI GF-1 at the dealership I guess. It has the yellow dot rear bar with the c pointing upwards.
You've been on here a lot, but Takahashi, I think is his name from down under has very good pics of putting on endlinks to fix this problem. he even had a chart of how many mm to shorten for how many inches or cm your car is lowered.
DOES ANYONE HAVE THAT ENDLINK SHORTENING CHART TO POST UP?
Old Jun 27, 2010 | 12:44 PM
REDRX3RX8's Avatar
Other members have photos of stock endlinks bent.
Yeah, we are all wondering: how can the rear suspension run out of travel on the endlinks before the shock bottoms out?
Old Jun 27, 2010 | 12:58 PM
zoom44's Avatar
have you made any changes to the car?stock suspension /stock wheels? alignment recently?
Old Jun 27, 2010 | 05:59 PM
LBrown8's Avatar
nothing at all i put new wheels on yesterday and alligned it yesterday to see if that fixes it but it didnt
Old Jun 27, 2010 | 07:29 PM
zoom44's Avatar
did you look at the shocks and springs?
Old Jun 27, 2010 | 07:44 PM
Mr.We$t's Avatar
Rx-8 the protege
Kinda have a similar issue but when I hit the breaks I hear a knocking sound and I hear it the most when I reverse and hit the breaks!! It sounds like it's cin from
the front suspension
Old Jun 27, 2010 | 07:52 PM
LBrown8's Avatar
shocks look fine they dont bounce , the sway links look a bit worn and i need to get a new set of break pads but i mean i dont see any major issues
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
just1jack
Sep 9, 2015 04:45 PM
