Are wheels alignment specs for rx7 and rx8 the same?
Old Jun 23, 2010 | 11:11 PM
tibyABv6's Avatar
I took my Rx8 to tire shop to do alignment (some time ago). Now looking at the sheet they gave me - it states model as RX-7 instead of rx8.
Does any one knows if wheels alignment specs for rx7 and rx8 are the same?
Old Jun 23, 2010 | 11:12 PM
that simply means they did it wrong + you are stupid enough to ask this question.
Old Jun 23, 2010 | 11:31 PM
yiksing's Avatar
the giant tastetickles
As long as they tune the alignment to stock factory settings or what you want, the label doesn't matter.
Old Jun 23, 2010 | 11:45 PM
mike[piston eater]'s Avatar
O' Let's do it.
yeah it does matter each car has its own alignment settings from the factory for a reason
Old Jun 24, 2010 | 12:38 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
When you take the car to a shop, the guy at the front desk usually puts the info into his computer for the shops records.
When the car is taken into the garage, the mechanic normally looks up the alignment info on his own alignment machine which has all the specs in it for each vehicle.
So, the answer to this question depends on whether the mechanic used "rx-7" to look up the specs in his machine when he did the alignment (and thus aligned the car to those specs), or whether he knew it was actually an rx-8 (and aligned it as such) and the guy at the front desk just screwed up when inputting the info to his records computer, which doesnt really much matter. The latter is more likely.
IF the mechanic aligned it as an rx7 then the specs are almost certainly different. I would probably clarify this between the front desk guy and the mechanic that did the work.
Old Jun 24, 2010 | 12:48 AM
O' Let's do it.
well i know when when i got my 8 aligned the alignmet shop couldnt find alignment setings for the 8 on the machine so we looked for it online
Old Jun 24, 2010 | 12:59 AM
TQCuong3th's Avatar
how much for aligment?
Old Jun 24, 2010 | 02:10 AM
IT means the shop is too cheap to pay for updates for the newer model year cars within the last 2 years or so...and that shop is probably to be avoided.
Mr.Durden
Aug 12, 2015 02:21 PM
MolsonB
Aug 8, 2015 01:24 AM
thewatcher101
Jul 27, 2015 09:44 PM
KingBonacci
NE RX-8 Forum
Jul 22, 2015 11:25 PM
RX7.9
Jul 20, 2015 12:01 PM
