1/4 Mile.
Old Jun 23, 2010 | 09:53 PM
RobGripper's Avatar
Cannada
Post 1/4 Mile.
I've been taking my car to the track lately and running the 1/4 mile. I have perfect launches, brand new tires, perfect shifting, but I've got nothing lower than a 16.1
Car has 95k on it and has never been rebuilt, what do you guys think? I know it's more than capable of low-mid 14's.
Old Jun 23, 2010 | 10:02 PM
gregs's Avatar
Pull My Finger
can you post your time slips..this will help see where the flaws and need for improvement may be
Old Jun 23, 2010 | 10:04 PM
Lvis's Avatar
TROLL
ouch... how were the conditions on the track/weather? i know that plays a big factor.
CrazyJek's Avatar
"I wanna go fast!"
How old r your plugs, coils, wires, ignition... etc.
Have you ran a compression test at all?
Maybe you lost a lil compression. How hot was the day? There are a lot of variables that can cause this. Do you have a sound system? Anything heavy in the trunk? How much do you weigh?lol
Old Jun 23, 2010 | 10:05 PM
maxxdamigz's Avatar
Baro Rex
I'd take the car in for a compression test before you roll 100k regardless of quarter mile times. It was tagged with a 14.6 I think stock which means it can run high 14s. Given the torque curve of the car, it's going to give up tens right off the line. Are you on stock coils? Age of plugs/wires? There are tons of areas where the car could be giving up power.
Old Jun 23, 2010 | 10:08 PM
bob07's Avatar
define "perfect" launches and shifting
im willing to bet that plays a role in your times
Old Jun 23, 2010 | 10:09 PM
RobGripper's Avatar
Cannada
I can't get my timeslips because they are in my car and it's not at home right now. Everything in pretty old and no compression test done in a long time. Best time was 16.11 @ 89mph. Was beautiful weather out, somewhere around 20 Celsius.
Bob: Perfect launches as in limited to no wheel spin & not dumping the clutch obviously, very quick shifting barely lifting @ around 8900 every time.
Old Jun 23, 2010 | 11:34 PM
gregs's Avatar
Pull My Finger
your trap speed says otherwise..there should be plenty room for improvement..without the information on your timeslip not really too much to be helpful insight can be made
Old Jun 24, 2010 | 11:38 AM
RobGripper's Avatar
Cannada
I'll grab the timeslip tonight, I have my car at mazda. I'm probably messing up somewhere and don't even realise it. Thanks a ton for the help you guys provided already.
Old Jun 24, 2010 | 12:44 PM
Roidz's Avatar
Strength/Confidence
+1, weather and altitude can play a big role.
Old Jun 24, 2010 | 12:48 PM
the1jesster's Avatar
Trained true Killers
At/mt ???
Old Jun 24, 2010 | 05:11 PM
Ztriumph's Avatar
Check out our launch... With these cars you need to launch them around 5k+, though not often as the obvious wear it will cause.
Due to the lack of torque it is the same issue first seen with the S200. When they first appeared no magazine could break into the 14's. When questioned Honda replied on how they launch the vehicles (dump at 5k) and the times dropped significantly.
This is why on a rolling start (5mph) our cars suck (check out any review where this was done). With these engines you need to be in the powerband coming out of the whole or you will never come close to the cars potential.
Old Jun 24, 2010 | 07:56 PM
0413B's Avatar
shouldnt leave the timeslips in the car when it goes to mazda?
Old Jun 24, 2010 | 10:01 PM
maskedferret's Avatar
Oooh, shiny!
For a point of reference in this thread:
My first (and so far only) run at a drag strip I obtained a time of 15.547 @ 90.72. Details are below. My car was pretty much stock; just running with a K&N drop-in filter and Moroso spark plug wires (woo!). Wheels are lightweight SSR Comp-H (17.5 lbs.) wrapped with 245/40-18 RE-01R's. I had maybe around 60k miles on the odometer.
10-20-2009
R/T: 0.889
60': 2.331
330: 6.629
1/8: 10.097 @ 70.12
1000: 13.048
1/4: 15.547 @ 90.72
Newbie excuses:
Did a mini-burnout when I probably shouldn't have.
Was caught by surprise when the lights went down so soon after lining up because I wasn't thinking straight. This led to a rushed (read sloppy) start.
Tires skipped like mad launching @ around 4000 RPM.
I think I fumbled a bit; hesitated on shifting into 4th being so close to the end.
I feel I'd have room for improvement if I ever cared to try again.
Old Jun 24, 2010 | 10:46 PM
Roidz's Avatar
Strength/Confidence
^^ I was pretty nervous my first and only time at the drag strip too. It made it tough getting the perfect launch.
Old Jun 24, 2010 | 11:27 PM
celbii's Avatar
Thumbs up
I lol'd irl
Old Jun 25, 2010 | 07:48 AM
MICHGoBlue's Avatar
With the 8's peaky power, with a clutch dump or high RPM clutch slip, the wheelspin is ok since it's a compromise to staying in the powerband.
I would say shifting just before the gas cut off of 9500 rpm is ideal, yes the peak power stops at around 8700, but by shifting around 9500, again you'll be staying at the idea powerband.
Old Jun 25, 2010 | 08:59 AM
wcs's Avatar
wcs
no agenda
Jesus you guys should try pushing the peddle on the right further down ....
(I kid I kid)
I've only ever done one run ... this is the time slip from my first and only run.
I didn't even bother to warm up the tires with a burn out.
I hope to do more this year.
I was on the right hand side
Mods at time
RB = Ram Air and Intake
RB = Flywheel
SRMotorsports Pulleys
Cobb AP = MM Tune
Oh ....
Did I mention a 55 shot of nitrous? lol
Ok since then I've added
Catless midpipe
RB Catback exhaust
65 Shot of Nitrous (might try the 75)
BHR Coils
Progress Sways to help eliminate wheel hop
Another MM tune for the catless midpipe
Old Jun 25, 2010 | 02:07 PM
wcs's Avatar
wcs
no agenda
^^^ PS
The car on the left was a 300 SRT8
With the air conditioning and traction control on.
My father really knows how to rub it in....
Old Jun 25, 2010 | 02:49 PM
fuztupnz's Avatar
Phone Booth'd
wow, the 300 was cookin' in the second half of the run
Old Jun 25, 2010 | 04:16 PM
Nicole711's Avatar
~Nicole~
I ran my stock R3 2 weeks ago and my best was 15.024, I had to launch around 4, any higher and my wheels just broke free. But I was pretty consistent with my times...I think you should definitely be able to run better times than a 16.11 =) I need to play around with things a little more, I want to break into the 14's next time around, still trying to feel things out though, car only has 2500 miles on it.
Old Jun 25, 2010 | 04:34 PM
Why are girls like this such a rare breed.
I doing my best to mold my daughter into a car loving bad ***
Old Jun 25, 2010 | 04:57 PM
bob07's Avatar
(I kid I kid)
Mods at time
RB = Flywheel
Cobb AP = MM Tune
Oh ....
Catless midpipe
RB Catback exhaust
BHR Coils
strong reaction time
Old Jun 25, 2010 | 05:23 PM
wcs's Avatar
wcs
no agenda
LOL
Ya my 63 year father had a epic launch time compared to his 38 year old son.....
I demand a rematch!
Old Jun 25, 2010 | 05:45 PM
wcs's Avatar
wcs
no agenda
@Nicole711
Nice avatar pic
