K&N Typhoon Intake V2 (before I get started)
Old Jun 22, 2010 | 02:17 PM
winning_blue's Avatar
Ordered the Typhoon Intake V2 from a member on here and it should be arriving shortly, just wanted to know if there is anything specific that I should know before getting started. I have gotten off the stock intake just to clean the inside filter before but never undone the whole thing. I have to step by step directions as well to install, but any pointers on things that may have tripped you up in the process? Just want it to go as smooth as it should. Thanks!
Old Jun 22, 2010 | 02:20 PM
dozer's Avatar
on his 3rd rx8
plain and simple, just make sure you dont start a fire under the hood, like SOME PEOPLE did to mine
Old Jun 22, 2010 | 11:56 PM
smooshinghead's Avatar
How did you start a fire?
Old Jun 23, 2010 | 12:49 PM
haha thats what i'm trying to figure out. if anyone has any real help on this, that'd be great!
Old Jun 23, 2010 | 01:25 PM
c0ldf1ame's Avatar
mine didnt come with MAF screws that bolt the MAF down to the new intake tube. So halfway through the install i had to call my friend to take me to the hardware store, that was about it.
Old Jun 23, 2010 | 03:10 PM
thats good. you happy with it though?
Old Jun 23, 2010 | 08:02 PM
RWatters's Avatar
I used the screws that came with the stock intake for my MAF and had no troubles?
The only thing that tripped me up when I installed it was it was a bit of a pain to get the heatshield bolted down on the passenger side. I ended up using a really long (and skinny) extension on a ratchet and ran it through the hole on top of the heatshield that the engine cover mounts to. Outside of that it was pretty straight forward and K&N's instructions helped me out.
I noticed that right after I installed the intake when I revved the car the RPMs would drop and it'd act like it wanted to die. After a spin around the block that problem went away.
The only thing I suggest is a week after the intake has been installed take your MAF out and clean it. Mine had quite a bit of oil from the new K&N filter on it. After I cleaned it that one time it's never built up on there again.
I love the intake and I've had no problems with it whatsoever. It's been on there for a couple of months now. The noise it makes is insanely awesome and insanely loud as well.
Old Jun 23, 2010 | 11:08 PM
nice! exactly what I want
Old Jun 24, 2010 | 02:48 AM
Twiztog43's Avatar
thats why you screw it in with your hands first and then tighten it with a socket wrench.
that is normal, because you changed intakes, you have to do a soft reset of the ECU, turn off the car, turn the key to ACC then tap the brake 20 times as fast as you can. if you do it correctly the oil gauge will go to empty and go back to normal. although this is not necessary, it would be recommended on top of cleaning the MAF sensor too.
i would agree, all the BS on the forum about loosing power is crap, unless you actually measure it somehow, a normal driver or daily driven car wouldnt notice the difference in power other than the loud sound.
read red in quote
Old Jun 24, 2010 | 06:54 AM
terch1's Avatar
Very easy install. Straight forward. Just follow the instructions from the manufacture.
Old Jun 25, 2010 | 10:35 AM
bump for anything else?
Old Jun 26, 2010 | 02:44 AM
toneskii707's Avatar
suck my smog
Get the RB air duct it works great with the k&n.
Old Jun 26, 2010 | 06:45 PM
thanks guys, got it on without any real problems..except it was a pain to get down and bolt the heatshield down to the car. I appreciate the help!
Old Jun 27, 2010 | 11:30 AM
RWatters's Avatar
Originally Posted by Twiztog43
read red in quote
I cleaned the MAF because I had oil in my intake tube. I also reset the battery, but didn't pump the brakes 20 times. I ended up doing that a few days later to cover all my bases since I thought the car was idling a little lower than it did before the intake. Ends up I was just thinking too much. lol
Old Jun 27, 2010 | 11:31 AM
RWatters's Avatar
How? There's no vacuum to pull air up into the intake. Or are you saying that it routes more air into the intake itself just by being there?
Old Jun 27, 2010 | 11:48 AM
Spoolin8's Avatar
Didnt this intake actually cause the car to lose 1-2hp on the dyno? They sound great but i would at least get the RB duct to help somewhat with the hot air being pulled in.
Old Jun 27, 2010 | 12:08 PM
I haven noticed any problems at all..didn't reset the ecu or anything. Idled better than before actually
Old Jun 29, 2010 | 12:36 AM
suck my smog
Exactly it routes more air to the intake while moving. I like the k&n because it allows me to mount the zex module on the backside of the shroud for a super stealthy look.
Old Jun 29, 2010 | 10:41 AM
If you have pics of the intake with the duct on I'd appreciate it..I'm a little confused still..
Old Jul 2, 2010 | 11:50 AM
suck my smog
Sorry I don't have pics of the duct on, you can't really see the duct enough to geta good picture. The rb duct takes place of the v fad but allows more air to come to the intake
Old Jul 6, 2010 | 08:53 AM
rx8dorifto's Avatar
any before and after dyno?
most of the aftermarket lost low end power compare to stock.
Old Jul 6, 2010 | 12:56 PM
idk if you are directing that towards me or toneskii, but I have FELT somewhat of a drop in low end power. needless to say it's nothing that much, love the sound, but in high RPM's I get through the gears quicker. I'm very happy with it.
WranglerFan
Aug 21, 2022 01:29 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
