Traction control light problem!
Old Jun 18, 2010 | 12:29 PM
SilkyJohnson's Avatar
I disconnected my battery to clean my cold air intake and put on a throttle body spacer and now when i start up the car the traction control light blinks and the DSC light stays on, and when i push the button nothing happens.. any help!?
Old Jun 18, 2010 | 12:34 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
You can crank the wheel from lock to lock to rest the stability control... and then traction control system light should go out in the next drive cycle.
Normal when you have the battery disconnected.
Old Jun 18, 2010 | 12:39 PM
tza0001's Avatar
Dum Spiro Spero
In simple words just turn your wheel all the way to the right and then all the way left and the light will go off. The light goes off even if you drive the car and take some turns, turn off the engine, turn on the engine.
xAgyex
Jun 3, 2026 03:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
bullbuchanan
26
Mar 24, 2016 12:37 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
MarkX
Jul 31, 2015 07:50 AM
