View Full Version : Grinding noise... Clutch Plate?
majjic
06-12-2010, 09:26 AM
G'day, majjic here, I'm new just recently took delivery of a 2003 6 Speed. I have noticed an odd grinding noise when in idle unless the clutch engaged (less noise in gear with clutch engaged). Car drives and handles well and I do love it, just courious about the noise.
Thanks in advance.
Side Note: also wondering about a stereo kit in Australia to fit a double din head unit with a control box.
Again Thanks
takahashi
06-13-2010, 02:54 AM
Congrats on the purchase.
The noise is the throttle body noise and it is normal.
c4nt1k
06-13-2010, 04:31 AM
what you mean by "clutch engaged" is when your foot stepping on the pedal? or when the clutch is not touched at all?
if the sound is gone as soon as u step on the pedal, its input shaft bearing. I heard from a few mechanics that its quite a common "problem" in rx8
if the sound is gone when u leave ur foot off the pedal, its clutch release bearing, could be from your aftermarket clutch/fitment by mechanic
dannobre
06-13-2010, 11:55 AM
There is a lot of rollover gear noise with the transmission in neutral and the clutch out..
majjic
06-14-2010, 02:56 AM
It happens when my foot is off the clutch and in neutral.
Thanks everybody!
Wantarotory
06-17-2010, 08:51 PM
takahashi is right...mine does this as well...its totally normal! :)
Jon316G
06-17-2010, 08:55 PM
Dannobre is correct on this one...
majjic
06-19-2010, 03:14 AM
Thanks Guys! you have put me at ease, being a new owner and all!
Cheers
