Wth?!
Old Jun 10, 2010 | 03:03 PM
MazdaRX-8SPEED's Avatar
White Eagle
Exclamation Wth?!
i just changed my oil and i put in 3 3/4 qrts of oil and when i check the level its showing me min. oil... and yes i started the car up after the change no leaks everything was fine, let the car run for like 5 min and then i turned the car off and let it cool for 5 min.
any ideas? lol
Old Jun 10, 2010 | 03:08 PM
The Reverend's Avatar
That's a lie
put more oil in?
the 8 has more than 4 quarts running through the oil coolers etc, so you probably just drained out more than you expected
Old Jun 10, 2010 | 03:12 PM
White Eagle
probably.. i just added more and im letting it run right now. and i did tilt the car to drain more oil out... oops. ill check after the warm up and ill report back.. thanks
Old Jun 10, 2010 | 04:07 PM
White Eagle
omg this is a little weird. i just added 4 qrts of oil and its barley half way lol
Old Jun 10, 2010 | 04:16 PM
8 Maniac's Avatar
Senior Member
I hope you dont mean 4 more quarts...
Old Jun 10, 2010 | 04:50 PM
White Eagle
yea i put 7 total qrts... no i put in a total of 4 1/4 qrts lol
Old Jun 10, 2010 | 05:01 PM
8 Maniac's Avatar
Senior Member
Just making sure... you never know sometimes. I've seen dumber things happen. I definitely would not add more than that. What year is your car?
Old Jun 10, 2010 | 05:04 PM
bose's Avatar
Reginald P. Billingsly
What's the question? The 8 with oil filter is 3.7 quarts now the oil coolers are holding at least a quart each.
How's your aim? Is it all going down the filler neck?
Old Jun 10, 2010 | 06:34 PM
White Eagle
i have an 04. yea i went to AZ and asked and they told me 3.7 grts. but i put a little over 4 qrts. and still didnt top it, but this is the highest im going. lol
Old Jun 11, 2010 | 09:37 AM
bose's Avatar
Just keep an eye on it the next few days, you should be fine as long as there's no leaks and it's above the low mark.
Old Jun 11, 2010 | 09:42 AM
RIWWP's Avatar
No, not OOPS. Draining out more of the old oil is a good thing. The entire oil system can hold something like 7-7.5 quarts. A normal drain only drains out 3.7 quarts officially, though it can change depending on how much you have burned off. Tilting the car to get more out of the oil coolers is something I do all the time, and I usually re-fill with about 4.5 quarts.
You are doing the right thing.
You can also get a Pela Pump to pump out the oil via suction through the dip stick, and that supposedly removes roughly 6 to 6.5 quarts.
But yeah, always check for leaks.
Old Jun 11, 2010 | 11:57 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
So, because a computer somewhere told you an inaccurate number, and you used that number, and your engine physically indicates that it is not enough, you are not going to finish the job and put in the amount of oil your engine physically needs. Because it is too far from the number you were originally given, so it cannot be accurate. Right?
Old Jun 11, 2010 | 11:42 PM
White Eagle
dont really want to blow **** up by adding to much oil if its my mistake... anyway its all good now. thanks lol
Old Jun 11, 2010 | 11:45 PM
Running low on oil can "blow **** up". Running a little too much oil won't do jack ****...worst case it'll blow some through the vent tubes into the intake tube. Of course it's best to run the correct amount per the dipstick, but if I had to choose between running a quart low and a quart over, I'd run over all day long. Maybe that's just my weird logic though.
Old Jun 12, 2010 | 06:06 AM
lol !!!!!
but seriously, what sup with "common sense" these days ...
Old Jun 12, 2010 | 10:12 AM
zoom44's Avatar
holy hell. im just gonna close this thread and say this- measure the oil that came out and you'll know how much to put in. even then need to check the dipstick to see if its full. a quart over is NOTHING to worry about a quart under IS.
http://www.ehow.com/video_11_change-motor-oil.html
MUGEN1800
Apr 23, 2011 02:26 PM
olddragger
12
Aug 1, 2010 01:31 AM
TeamRX8
RX-8 Racing
11
May 5, 2010 06:51 PM
DreamWarrior
Dec 21, 2004 09:13 AM
