RECOMMEND FAST:Car adhesive removal
Old Jun 10, 2010 | 10:44 AM
radiantglossy's Avatar
can anybody tell me what i can use to removed the stain of the adhesive used to glue and advert to the body of my car. The branding is all over my car, after i had removed the sticker all the body of the car................the stain of the adhesive is still there. please what can i use to wash it off?
Old Jun 10, 2010 | 11:08 AM
CTrx8's Avatar
space for rent
Goo Gone
Old Jun 10, 2010 | 11:16 AM
Cf05's Avatar
Not Faster Thn Ryans Spd3
^+1 just used that on some pin stripes it works great just make sure you wash it off after
Old Jun 10, 2010 | 05:40 PM
BigMikeATL's Avatar
Here's what I did recently and it worked like a charm:
1) Use a hair dryer to heat up the decals a bit. This will allow you to peel them off easier.
2) Use an old cotton t-shirt and some Goo Gone Sticker Lifter. You will have to use a little pressure to get the goo moving. DO NOT try to get it all off this way. Just some big bits of goo. Soak it with the stuff and rub.
3) Now, take another shirt and apply a liberal amount of 70% rubbing alcohol to the remaining goo and the shirt. You should be able to wipe the stuff of really easily. Just keep applying alcohol and wiping with a little pressure.
When done, rinse with water and dry throughly. You don't want to leave any solvent on the finish.
Old Jun 12, 2010 | 02:26 PM
supergoat's Avatar
I don't "smell good".
old credit card, some warm water and elbow grease. Done.
Old Jun 12, 2010 | 02:57 PM
PhillipM's Avatar
Wd40
Old Jun 12, 2010 | 04:33 PM
+1
elbow grease FTMFW !
Old Jun 12, 2010 | 09:20 PM
rodjonathan's Avatar
silent assasin
goo gone ftw
Old Jun 12, 2010 | 10:11 PM
kersh4w's Avatar
Hit & Run Magnet
what if my elbow isnt greasy?
Old Jun 12, 2010 | 11:51 PM
make it greasy.
Old Jun 13, 2010 | 09:37 AM
shinka_chick's Avatar
the hair dryer thing always worked well for me
Old Jun 14, 2010 | 04:06 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
wd40 or other similar spray lubricant
3m adhesive remover with plastic scraper, available at paint/body shop supply stores.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Racingjunkie
Sep 29, 2015 05:05 PM
Learners_Permit
Sep 27, 2015 07:38 PM
