flatso
02-01-2004, 10:07 PM
Will it cause any known problems?
View Full Version : Can you add dry gas to a rotary engine? flatso 02-01-2004, 10:07 PM Will it cause any known problems? MikeA 02-01-2004, 10:21 PM DRY GAS???? 93rdcurrent 02-01-2004, 11:48 PM I haven't been able to get my rear end to seal over the gas receptical. Let us know if this improves your gas mileage. jimyoung 02-02-2004, 12:10 AM This is a valid concern with the weather people are enjoying. Maybe someone with lots of rotary engine experiance can answer. I have been using 1 bottle of iso heet ,which is mostly alcohol, every other tank full to eliminate water that I may have come across in the fuel that I use. Also driving in cold weather and parking inside warm will create water condinsation in the tank. Am using Chevron premium w/ techron. Have seen no ill effects but long term use info would be interesting to hear. |
