Engine Management Light
Old Jun 9, 2010 | 11:15 AM
LjgibboRX8's Avatar
UK Engine Management Light
Hi All,
I need help, i was driving my RX8 to work this morning and my Engine Management light come on the dash board. I continued to drive my car and it was running as normal? Will this harm my car or could you suggest the fault?
Cheers
LJGibboRX8
Old Jun 9, 2010 | 11:20 AM
bse50's Avatar
#50
The only way to tell what's happening is to hook and obd reader up and get the codes.
Since you didn't experience any other inconvenience it may be just a faulty o2 sensor or a bad catalyzer.
A bit of car history?
Old Jun 9, 2010 | 11:37 AM
RIWWP's Avatar
I assume you mean the check engine light (CEL)
Here is a list of possible codes that it could be:
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/ (yes, that is 115 possible codes)
And yes, it could be anything from you didn't tighten the gas cap the whole way to your ignition is failing to your intake valves have issues to your emissions equipment is failing to your engine has imminent failure.
The light by itself doesn't tell us anything.
Was there anything else going on at the time the light came on? Any power issues, any idle issues, any hard start, etc...
Old Jun 9, 2010 | 12:16 PM
zoom44's Avatar
did you get petrol yesterday before putting the car away for the evening? or this morning and then stop somewhere for a bit before continuing on and getting the light?
Old Jun 9, 2010 | 03:43 PM
LjgibboRX8's Avatar
UK
Hi Guys,
Thanks for the information, The light come on why i was driving down the Motorway this morning @ 70 mph? Ill have to get it checked out...
Cheers
Boyz
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
RayBarron
Oct 19, 2015 08:08 PM
MarkX
Jul 31, 2015 07:50 AM
Bamaham
Jul 23, 2015 08:08 AM
