quick taillight question.
Old Jun 8, 2010 | 07:25 PM
MazdaRX-8SPEED's Avatar
White Eagle
so i had the water problem with the rear pass. side so i drilled some holes, but the water that was in there sloshed around and now i have the ugly marks on the inside of the plastic. my question is... how can i get inside if the housing? im guessing by baking the housing for 15 min on low temp and open it up? if im wrong or right please tell me haha
thanks!
Old Jun 8, 2010 | 07:28 PM
Twiztog43's Avatar
you could bake them to get inside the housing
Old Jun 8, 2010 | 07:37 PM
White Eagle
okay. um how high is the temp supposed to be and how long should it bake for? lol
Old Jun 8, 2010 | 07:44 PM
laythor's Avatar
I zoom therefore I am.
http://www.youtube.com/watch?v=ok1a9jyfRYw
Old Jun 8, 2010 | 08:52 PM
Nouvellion's Avatar
Recovering Lurk-aholic
Do Not bake open your tail-lights. AFAIK, the plastic bits are fused together permanantly and the only possible result is melting them. (Searching for a citation on this currently)
Get some white vinegar and use that to rinse off any water spots.
Old Jun 8, 2010 | 08:57 PM
Easy_E1's Avatar
Old Jun 8, 2010 | 08:59 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
not bakeable.the downside of drilling holes is now you get dust and stuff that gets in to make it dirty. clr.
Old Jun 8, 2010 | 10:04 PM
White Eagle
no just that the water that was in there left these ugly looking lines oh well haha
Old Jun 8, 2010 | 10:14 PM
hokie027's Avatar
I had the same problem, so I air dried them out... then bought the bigger seal--which worked for about 10months. Then I had the water problem again after a big rain, so I ended up having to replace the taillight all together. My suggestion, rather than mess with the light for the next few months letting it drive you crazy, is just to just replace it.
Too bad the new taillights aren't a perfect fit into the 04-08 models... that would make for a sweet replacement.
Old Jun 8, 2010 | 10:21 PM
unknown__Disciple's Avatar
i have an 09 and water still gets in them...im not even at the 10,000 mark on the odometer
Old Jun 9, 2010 | 04:38 AM
Chad D.'s Avatar
Spinnnnnnnnnnn
you've got lines b/c the water is dirty. Try CLR, dry it out with a heater. Clean and cake your gasket with silicone, reinstall, it should be fine.
Old Jun 9, 2010 | 07:20 AM
Myriad's Avatar
Distilled Water, slosh it around, drain out what you can, airdry, buy a gasket, close the holes and refit the gasket with sealant, reinstall. That's what I did and it worked great.
neoksk
Sep 21, 2015 12:31 PM
Wurromurro
Sep 20, 2015 05:02 PM
RXBae
Sep 14, 2015 03:54 AM
yankeepicker
Sep 11, 2015 05:42 PM
