RX8 idling vibration
Old Jun 8, 2010 | 10:22 AM
janwillem's Avatar
My 2005 RX8 tends to vibrate when I'm in Drive at an idle. Seems to be worse when cold. Anyone have thoughts?
Old Jun 8, 2010 | 10:50 AM
deadphoenix52's Avatar
meh.
http://www.finishlineperformance.com...01-09-2062.pdf
Old Jun 8, 2010 | 11:48 AM
tcole6's Avatar
I have an MT that after driving for awhile and fully warmed up has a little vibration when resting at a stop light. Nothing more than some other vehicles I have owned (like an older LX 5.0 I had), which I attribute to a little bit of a low idle setting.
The car runs absolutely beautifully and never stalls or anything. Is this anything I should be concerned about? If it were a pissed-in car (get it) I would probably not give it a second thought...
Thanks.
Old Jun 8, 2010 | 11:53 AM
laythor's Avatar
I zoom therefore I am.
never hurts to check all the things that can cause it
1. motor mounts
2. plugs
3. wires
4. coils
5. maf sensor
6. filter
Most things you can check yourself and or clean/replace.
Old Jun 8, 2010 | 12:00 PM
tcole6's Avatar
Thanks for the advice. I think the mounts are okay, the car shifts clean and I don't notice any unusual movement under heavy acceleration.
I have questions about the coils as I've read that mentioned often on the forums. What kind of early warning signs should I be looking for on the coils? I hate to just replace them because my car has 20,000. But I would hate more to be roadside....
Old Jun 8, 2010 | 12:10 PM
RX8Lovah's Avatar
our rx8 also has a rough idle. the Shifter stick vibrates like crazy. but the vibration stops when going.
Old Jun 8, 2010 | 12:12 PM
laythor's Avatar
http://www.finishlineperformance.com...16-07-1793.pdf
Old Jul 28, 2010 | 11:36 AM
Faria's Avatar
LikeThunda
i just replaced my Coilpacks, Wires, and Sparkplugs... and MotorMounts....
my car started to vibrate at idle a little....the shifter shakes aswell....
while removing the intake assembly...i broke the plastic tube that goes into top part where you put in the oil?? could this cause an unsteady idle???
i tried to plug them but didnt feel a difference..
Old Jul 28, 2010 | 11:50 AM
Bigbacon's Avatar
2006 WB AT
does it get A LOT worse when the AC is on?
Old Jul 28, 2010 | 11:53 AM
Faria's Avatar
LikeThunda
i cant say..I Just put in a MishiMOtor Radiator....and i didnt put back my AC//// so... no need to turn it on..
Old Jul 28, 2010 | 11:54 AM
Bullitt's Avatar
In the pipe five by five.
So white spots DON'T indicate a bad coil? Hmm. Well, mine shakes some now after putting in new plugs/coils.
Old Jul 28, 2010 | 11:55 AM
xun4gvn4everx's Avatar
True love is blue x2
OEM coils are good up to 30k miles, so it is getting close for you to change them. Without looking at your car in person, the symptoms you describe could be due to your coils, plugs, and wires in need of changing.
Old Jul 28, 2010 | 11:57 AM
Faria's Avatar
LikeThunda
my car started misfiring really bad.... so i just replaced everything..plugs coils wires.....it runs smooth now..except for that vibration at Idle.....
hmmmm
Old Jul 28, 2010 | 12:41 PM
Bigbacon's Avatar
2006 WB AT
does it get worse then if the fan comes on or if you turn on the fan?
Old Jul 28, 2010 | 12:42 PM
Faria's Avatar
LikeThunda
nah,, i dont think its a Alternator issue,, possibly a battery/ground issue?? since it was sitting for so long...
Old Jul 28, 2010 | 12:54 PM
terch1's Avatar
What makes you assume the mounts are ok? Did you have them inspected by the dealer or someone familiar with the 8? It could be the coils or plugs as mentioned. However, in most instances it apears to be engine mounts. My car had a shimmy to it. Vibration was worse at idle. Replaced my mounts and the issue is gone.
Old Jul 28, 2010 | 01:52 PM
VashGS's Avatar
Zoom Zoom Addict
Is your window fluid tank black or clear? If it's black (they mad a set of fixes middle of 05 production run).. your mounts are probably cooked / shot. There is an upgraded mount for pass side that fixes a material defect (mazda slipped by another re $$$ call).
Old Jul 28, 2010 | 01:56 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
"Is your window fluid tank black or clear? If it's black (they mad a sex of fixes middle of 05 production run)."
Say.........WUT?
Did you mean"they made a set of fixes"?
But I do agree...........I'd go after the passenger side mount first above all else!
Old Jul 28, 2010 | 01:57 PM
VashGS's Avatar
Zoom Zoom Addict
lol typo SET..
I don't know exacly when the newer mount part started going into production.
Old Jul 28, 2010 | 02:17 PM
Renesis07's Avatar
Vtak just kicked in yo!!
all RX8s Ive been in seem to idle rough, I was convinced my motor mounts were toasted, but after doing my subframe replacement and checking them, they looks perfect (yes perfect after 80K miles, I was shocked too!).
Some seafoam and new coils should smooth it out a tad. But so far Ive been in ONE single RX8 that didnt have harsh vibrations. The other billion Ive been in were rattle ****** just like mine.
Old Jul 28, 2010 | 02:43 PM
Easy_E1's Avatar
Engine mounts.
Old Jul 28, 2010 | 03:20 PM
Detrich's Avatar
幹他媽!
my engine idles and makes a "lapping noise" like a swoosh swoosh swoosh swoosh. took it to the stealership and they couldn't reproduce it- since it happens intermittently. i have 10k miles on my car.
i this point, i guess i will will deal with it at the next oil change- maybe go somewhere else. mazda dealerships suck and can't do anything except scratch up my car every time i bring it in for service. or, maybe i'll upgrade to something else altogether. will see...
Old Jul 28, 2010 | 10:10 PM
DocBeech's Avatar
I drive at Red Line.
are you sure its abnormal? The rx8 is direct connect into the transmission, where as other cars have linkage. Some vibration is normal in the shifter since your directly connected to the driver shaft and engine with no linkage or assembly in between.
Old Jul 28, 2010 | 10:37 PM
jasonrxeight's Avatar
my mirrors and gear **** vibrate abit.
Old Jul 28, 2010 | 10:45 PM
DocBeech's Avatar
Thats because you live way up north where all the roads are heaved from your freezing weather:P
