bassik277
02-01-2004, 03:35 PM
Im considering getting 18" volks, 9.5 rear, and 8.5 fronts, and was just wondering how you get your wheels rotated when it is a staggered setup? Does it cause a problem with wear? thanks a lot guys
-Alex
-Alex
View Full Version : Important Question about Staggered Setup bassik277 02-01-2004, 03:35 PM Im considering getting 18" volks, 9.5 rear, and 8.5 fronts, and was just wondering how you get your wheels rotated when it is a staggered setup? Does it cause a problem with wear? thanks a lot guys -Alex epitrochoid 02-01-2004, 08:38 PM you dont Koala Joe 02-02-2004, 12:44 PM You can't rotate tires with a staggered set up. The only way to rotate the tires is if you get "bi-directional" tires, which means you can flip them in both directions. With staggered setup and with "bi-directional" tires, you can rotate the front tires by switching sides, and you can rotate the back tires by switching sides. But you can't rotate front to back or back to front. Does this make any sense? xxpersianoxx 02-06-2004, 01:23 AM You mean A-symetrical tires??? Gord96BRG 02-06-2004, 10:43 AM Originally posted by xxpersianoxx You mean A-symetrical tires??? They could be asymmetric, as long as they're not directional. Side to side rotation is possible if you can reverse the direction of rotation. Regards, Gordon |
