Mazfix Oil Cooler
Old Jun 6, 2010 | 07:30 AM
tofu_box's Avatar
Mazfix Oil Cooler
I saw on Mazfix's website they have a oil cooler kit for sale there for 725, much less then from other sources here and its local.
Now the deal is whats the quality of this kit?
Does anyone have experience with it?
Or does it really not matter that much?
Regards
Jason
Old Jun 7, 2010 | 01:04 AM
skc's Avatar
skc
rev it up
I got one done by Mazfix. They are sourced from PWR. Mazfix then make up the appropriate brackets and hoses and install it for you.
skc
Old Jun 7, 2010 | 02:56 AM
Giustino's Avatar
http://www.carboninmotion.com/produc...m?productid=35.
send these guys an email to check warranty on lines and freight charges, but the price seems to be too good to be true.
Old Jun 7, 2010 | 04:52 AM
auzoom's Avatar
Hmmmmmm.........
Then it must be
Old Jun 7, 2010 | 04:18 PM
rotarenvy's Avatar
look at where carboninmotion are routing the oil lines. it works but not very neat. it doesn't even look like the oil lines are restrained.
another option would be racingbeat oil-line kit and source your own cooler of a suitable shape for the driver side. although it would be hard to beat the maxfix price.
Old Jun 9, 2010 | 06:04 AM
tofu_box's Avatar
are you running a 2nd oil cooler rotaenvy with ur supercharger?
If you did what oil cooler you running?
Regards
Jason
Old Jun 9, 2010 | 06:09 AM
Brettus's Avatar
Boosted Kiwi
I have run the stock second oil cooler as a 2nd water radiator for 18months now and i'm sure i make a lot more power than you will get from the SC .
Don't have any overheating issues whatsoever - track tested . The only time i've had an issue is when I put a big *** intercooler blocking airflow to the rad.
thread on it here .....
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/cooling-mod-idea-155235/
Old Jun 9, 2010 | 04:38 PM
rotarenvy's Avatar
Regards
Jason
no cooling mods, apart from a lower temp thermostat. it helps but isn't a cure.
Old Jun 9, 2010 | 04:47 PM
Wow, that's expensive. I know I am in the US but I replaced both stock coolers and lines with a 28" single Fluidyne (awesome) and in Texas heat my oil temps are kept down on and off the track. I also saw a nice bump in oil pressure too (though to be due to the shorter, less restrictive, larger hoses. I also installed a real oil thermostat. It may be over kill but I did eveything for around $300.00 (bought the oil cooler on ebay slightly used off a NASCAR).
https://www.rx8club.com/showthread.p...gle+oil+cooler
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
