Install:Aluminum/radiator,reservoir,breather
Old Jun 5, 2010 | 05:53 AM
mangnok's Avatar
Talking Install:Aluminum/radiator,reservoir,breather
just change radiator and coolant tank make it seperate it to reservoir and breather
so it's have Mizu radiator
Greddy breather
and aluminum reservoir circuit sport
Old Jun 5, 2010 | 12:11 PM
Phantom RX's Avatar
Good lookin install. Thats the same rad I have been looking at. Let us all know if it runs cooler.
Old Jun 5, 2010 | 12:27 PM
Where did you get that reservoir?
Old Jun 5, 2010 | 12:54 PM
Not bad looking. but it looks like same size as OEM.
Old Jun 5, 2010 | 01:01 PM
Mizu radiator?
Any particular reason you went with that one? I don't know much about them so I'm just wondering.
Old Jun 5, 2010 | 01:22 PM
Phantom RX's Avatar
I dont know why mangnok got his...
but the main reason I wanted the Mizu radiator was it was the only radiator with 3 cooling rows as opposed to 1 like all the others i have seen.
The price isn't to bad ether.
Old Jun 5, 2010 | 01:32 PM
Easy_E1's Avatar
Waiting for cooling results.
Old Jun 5, 2010 | 01:43 PM
bse50's Avatar
#50
From their website:
The Mizu performance aluminum radiator is the perfect upgrade to your stock radiator. Made from the highest grade of aluminum, all Mizu aluminum radiators are hand-welded and hand-made to create a perfect radiator with a direct OEM fitment without any cutting or modification needed. All Mizu radiators are designed and engineered to maximize cooling efficiency by increasing the radiator core's thickness, fin density and using 2 radiator cooling rows as opposed to 1. These advancements in cooling technology will protect your car from overheating under the harshest conditions. All Mizu radiators come with a high pressure 1.3 bar Mizu radiator cap and an unparallel lifetime warranty.
Given the flow problems that we have i'm not really sure how the increased fin count will work.
The price is ok though so seeing the results will be interesting.
Old Jun 5, 2010 | 02:15 PM
mangnok's Avatar
run it for a day now no problem with it
Old Jun 5, 2010 | 02:44 PM
mangnok: do you have any way of monitoring your coolant temperatures?
Gauges?
accessPORT?
would be nice to know before / after results.
Also, what water / coolant mixture % did you use?
Old Jun 5, 2010 | 02:49 PM
mangnok's Avatar
i use coolant the one it's 50/50, no gauge ,no accessport but gauge might be add later on
Old Jun 5, 2010 | 02:54 PM
mangnok's Avatar
but i think i gonna change coolant to the one from toyota
Old Jun 5, 2010 | 02:57 PM
why would you use Toyota coolant?
My recommendation: More water, less coolant.
I use 70% water, 30% coolant + 1 bottle of water wetter.
venom914's Avatar
how much did this the radiator run you? with shipping and everything?
Old Jun 5, 2010 | 02:59 PM
mangnok's Avatar
Originally Posted by venom914
how much did this the radiator run you? With shipping and everything?
$215
Old Jun 5, 2010 | 03:00 PM
mangnok's Avatar
why 70/30 ?
Old Jun 5, 2010 | 03:04 PM
mangnok's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...d=370390196998
same as this one but i got it from my mechanic
Old Jun 5, 2010 | 08:07 PM
bse50's Avatar
#50
Installing a new radiator without having a gauge and without any kind of empirical before\after tests makes your opinions useless and i'm sorry to say that because a new, useful and cheap radiator may be good for some.
This reminds me of the hype that the koyo units brought with them when they came out, unfortunately those radiators were found to make matters worse cooling wise after some time.
Old Jun 6, 2010 | 01:38 PM
boarderjosh10's Avatar
Resident Cool Guy
where did you get that coolant reservoir?
Old Jun 6, 2010 | 01:41 PM
nuke0907's Avatar
Never Blend In
he already answered that question 2 posts up.
Old Jun 6, 2010 | 02:05 PM
mangnok's Avatar
Thank you nuke
Old Jun 7, 2010 | 01:06 PM
mangnok's Avatar
yesterday i feel one thing good i'm drive with 91 degree out side and when i'm park like last year i have stock radiator after turn off the car radiator fan will turn on by it self about 5-10 mins but yesterday it's turn on only about 1 min so it's seem like it's cool down faster
Old Jun 7, 2010 | 01:56 PM
Originally Posted by mangnok
why 70/30 ?
water is the best coolant we can use.
The green radiator fluid works well as a lubricant and to ensure that things do not rust but in our weather, we do not need as much coolant because we won't see below zero temps.
Most people in hotter climates use more water then coolant.
Old Jun 7, 2010 | 02:32 PM
mangnok, what did you do about the radiator fluid level sensor?
Old Jun 7, 2010 | 03:09 PM
mangnok's Avatar
take it off sit in garage :D
