aftermarket exhaust header -- worth it?
Old Jun 1, 2010 | 01:32 PM
BigMikeATL's Avatar
I have been thinking about replacing my exhaust header and catback, mainly for theatrical effect, though a few extra horses never hurts.
I'm just wondering if an aftermarket header is worth it when you consider that the stock header does such a great job of protecting everything in the engine bay from heat.
Are there any risks when running an aftermarket header with a stock cat?
Mike
Old Jun 1, 2010 | 04:00 PM
BJP's Avatar
BJP
From what i've heard, it's not really worth it...but if you have money burning a hole in your pocket, go for it!
Old Jun 1, 2010 | 04:29 PM
invasion08's Avatar
Racing Beat claims that their header produced a peak horsepower improvement of over 4 HP. There are no risks with running a header with the stock cat.
Old Jun 1, 2010 | 05:00 PM
bse50's Avatar
#50
Yes but it would be useless to replace the headers before removing the real bottleneck
Old Jun 1, 2010 | 05:04 PM
invasion08's Avatar
True, I would personally replace the stock cat with a high flow cat, since i want to stay emissions legal here in nj. I was just answering the question the OP asked
Old Jun 1, 2010 | 06:07 PM
BigMikeATL's Avatar
What about heat from the header? Anyone done any measurements?
The aftermarket ones I see are all stainless steel while the factory one is some sort of double steel tubing.
What's the best bang-for-the-buck high flow cat?
Old Jun 1, 2010 | 06:12 PM
batangisip89's Avatar
RP Supercat its the best in price for what you get IMHO.
Old Jun 1, 2010 | 06:32 PM
invasion08's Avatar
The oem exhaust manifold is made of cast iron. There is no need to worry about heat coming from the racing beat header. If it was a problem racing beat would have done something about it. They do a lot of testing before the final product goes into production.
Old Jun 1, 2010 | 08:15 PM
tofu_box's Avatar
headers wont give you peak hp, but they give you mid range gains in torque and hp.
Combined with tuning, (for a auto)
I saw a improvement at 140kmph from 52kwrw to near 88kwrw that was a 3rd gear pull.
You can see the dyno on the auto in my post there.
Mind you i got a hi flow cat put in at same time.
Regards
Jason
Old Jun 2, 2010 | 09:01 PM
bumblebeerx8's Avatar
Rear Mount GT35R
i run a header that i had ceramic coated. i cant say i see gains but i got some sound and cooler around the motor. if any gains are there its more mid range power. and like another said a good tune will help too
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Brokegang
Jan 3, 2016 12:45 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
