Fuel Trims
Old Jun 1, 2010 | 01:07 PM
stinksause's Avatar
The Stink w.o The Sause
Fuel Trims
Is there a good place to get some info on fuel trims (long and short term)? How they work? How to reset them, etc?
Kinda of a newb question, I know, but a quick search didn't really show up anything
EDIT: Fuel trims are very useful for scaling MAF and seeing when your car is in open loop in datalogs.
When your car enters open loop STFT (short term fuel trim) becomes 0
Scale MAF by multiplying the flow rates by half your LTFT ...
EX: say your LTFT is 10%, then multiply the relevant area by 1.05 ....etc
Old Jun 4, 2010 | 09:37 PM
arghx7's Avatar
www.autoshop101.com/forms/h44.pdf explains it and gives background information
Old Jun 5, 2010 | 06:12 PM
stinksause's Avatar
great article ... thanks!
Old Jun 5, 2010 | 10:09 PM
hakuna matata!
Deviation corrections.
Cryptic answer I know but that's what they are in a nutshell.
Old Jun 6, 2010 | 12:20 AM
stinksause's Avatar
^ yea I figured as much
Old Jun 6, 2010 | 09:05 PM
arghx7's Avatar
short term fuel trim is proportional correction and long term fuel trim is integral correction. GM was doing this way back in the 80s...
Old Jul 10, 2010 | 04:03 PM
smooshinghead's Avatar
I have been data loggin with my accessport. I understand anything over +10 and - 10 should be corrected. I have a k&n typhoon intake and have seen up to 19 and down to -22. How do I get these values as close to zero as possible? I am new to this but I understand the concepts just not the steps to apply them. Any help would be appreciated.
Old Jul 10, 2010 | 05:57 PM
hakuna matata!
Assuming that is your LTFT.. you can fix that by scaling your MAF and/or fuel injectors accordingly.
That's assuming you don't have a vacuum leak somewhere. Those numbers are terrible.
Old Jul 10, 2010 | 06:18 PM
How do I scale my maf? Those are my stft.
Old Jul 10, 2010 | 06:22 PM
hakuna matata!
Then its irrelevant.. what is your LTFT?
Also I have an 04 mt with black halo racing ignition kit with msd wires, k&n typhoon intake, and accesscobb stage 1 tune. So you get a better idea of what I have. Please understand this all new to me but I am trying my best to understand what's going on.
Old Jul 10, 2010 | 06:26 PM
My ltft never goes over 6
Old Jul 10, 2010 | 07:32 PM
Correction is stays beween 4 and 8 all the time.
Old Jul 10, 2010 | 08:10 PM
stinksause's Avatar
If you are within +-5% for your LTFT, it is ok ... where in the load/RPM range are you experiencing this? At idle? At Cruise? At WOT throtle pulls?
That is the first question you need to ask. Then you need to scale your MAF in the correct ranges accordingly
Old Jul 10, 2010 | 09:18 PM
Its at 4 while cruising and 8 at wot.
Old Jul 10, 2010 | 10:35 PM
stinksause's Avatar
What is it at idle?
I am assuming its +4% and +8% ... then I would scale my MAF by multiplying it by 1.02 and 1.04 in the corresponding areas, reflash the map, drive for a week or so and then see what your new LTFT is .... dont forget to smooth after you change the MAF scaling tho
Anything below like +-5% is okay .... but if you wanna be **** about it, you can still scale it.
Old Jul 10, 2010 | 10:56 PM
I don't know how to scale it? Or how you got those numbers.
Old Jul 10, 2010 | 11:36 PM
stinksause's Avatar
this is where I got the numbers. I am assuming you said these are your LTFT % values, no?
To scale go under the Sensor Cal. Tables folder and the MAF Calibration table
Old Jul 11, 2010 | 10:39 AM
Yes those number are +4 and +8%. But how do you get 1.02 and 1.04 and what numbers do I multiply them by? And what is smoothing? Sorry for all the questions but I have read a engine management system books but nothing tells you the process you take to make changes. And I have searched this site and found nothing. Just more info shared by people who know what they are doing.
Old Jul 11, 2010 | 11:42 AM
I have seen one forum that says you should take the short term and long term add them together and use that number. And it says you shouldn't change the first 2 cells. I'm assuming those are .086 and .098 but i don't really know.
Old Jul 11, 2010 | 08:49 PM
stinksause's Avatar
First two cells are pretty much your idle, and low rpm cruise ... stft gets converted into ltft over time ... so make smaller changes to be safer ... I would rather be safe and make two changes, than make one wrong one...
... right click and interpolate, that's smoothing
Old Nov 4, 2010 | 11:34 AM
map's Avatar
map
Noob fuel trim question. I noticed yesterday that my ltft is +15. This seems high, and I was curious if it means possible issues, or is it in the range that could be considered normal? I am running MM base tune currently.
Old Nov 4, 2010 | 11:49 AM
DarkBrew's Avatar
Extraordinary Engineering
I recommend posting a data log file in the Cobb datalogs thread
Old Nov 4, 2010 | 12:11 PM
map's Avatar
map
Good suggestion DarkBrew. I will use that thread to try to learn what is "normal".
As for my initial concerns, it was another example of the old adage a little bit of knowledge is a dangerous thing. I thought ltft was relatively stable, but it varies more than I thought. I am over +10 at idle and coasting, but on the gas it is only +1. I guess that value is not as strange as I thought.
Old Nov 4, 2010 | 12:38 PM
You either have an intake leak or fuel system issue like weak pump, fouled injectors etc.
