RotaryZZ
01-30-2004, 09:22 AM
Does anyone know the exact specification for our 18" wheels. Is it 18x8 or 18x8.5? What's the offset and how much it weights.
TIA,
Pete
TIA,
Pete
View Full Version : Spec for the stock wheel RotaryZZ 01-30-2004, 09:22 AM Does anyone know the exact specification for our 18" wheels. Is it 18x8 or 18x8.5? What's the offset and how much it weights. TIA, Pete RotaryZZ 01-30-2004, 09:55 AM Also, what's the size of the wheel nuts? Is it 16mm?? mdw33333 01-30-2004, 02:07 PM 18" x 8" 5 x4.5" bolt circle, as for the offset, I'm not sure, I've been told it's +45 or +50. The lugs are 12mm x 1.5. RotaryZZ 01-30-2004, 03:01 PM Thanks. Do you know how much it weights too? Koala Joe 01-30-2004, 06:04 PM The Stock Rims are 18x8 all around, with offset of +50. Bold pattern is 5x114.3. Weighs about 26lbs each. RotaryZZ 02-01-2004, 02:10 PM Btw the lug nuts for the 18" wheels is not 12mm. I've asked the parts dept of one nearby dealer and they don't even know about it. Pathetic!! My guesstimate is 20mm. Do anyone know for sure? TIA, Pete DUGS_REX 02-01-2004, 02:38 PM Originally posted by RotaryZZ Btw the lug nuts for the 18" wheels is not 12mm. I've asked the parts dept of one nearby dealer and they don't even know about it. Pathetic!! My guesstimate is 20mm. Do anyone know for sure? TIA, Pete I believe the 12mm was referring to the Threaded Stud Diameter, not the Size wrench you need to remove the nuts. |
