HID length
Old May 3, 2010 | 03:27 PM
boostin4's Avatar
HID length
so i bought a hid kit from ebay and when installing i noticed that the bulb length was different. my buddy bought one for his car, MS3, and his came with an adapter for space length. is there a way to get these or a vendor that sells correct bulbs? why did mazda make different bulbs
Old May 3, 2010 | 03:36 PM
RotaryP7's Avatar
Seriously.. FML..
I'm guessing you have the non-HID model 8 right? Are the bulbs H7? The HID kit I have were pretty much the same size? They were slim style bulbs. Here's the kit I bought. Best $100 I've spent on the 8. I never trust those ebay HID kits..
http://www.therpmstore.com/product_i...products_id=38
Old May 3, 2010 | 03:56 PM
luv4eternity's Avatar
Low is a lifestyle
how do i find out if my car i HID or not ?
Old May 3, 2010 | 07:22 PM
Twiztog43's Avatar
do you have fogs?
Old May 3, 2010 | 07:25 PM
Spinning Sushi's Avatar
I <3 Sushi
Is yours a Sport/Base trim model? If so then you do not have HIDs.
Old May 3, 2010 | 08:18 PM
Low is a lifestyle
Originally Posted by Twiztog43
do you have fogs?
yes i do
i think its sport/base (no sunroof/ cloth seat/no heater/ no rear mirror garage opener)....but when i start , it takes a while to get bright....sorta like getting brighter ....
04 lightning yellow 6spd manual. my lights take a while to turn on (1-2 seconds)....like when u turn on , it gets brighter when hotter....isnt that how HID's are ? im super confused
Old May 4, 2010 | 01:22 PM
Krazed_Rx8's Avatar
^ Uhm thread jack?
But on a serious note judging on your description you have HIDs. Park your car near a wall & facing it, you should notice a cut off line. If so then you have HIDs.
Old May 4, 2010 | 08:47 PM
jefecito87's Avatar
Jefecito87
my friend bought some HID housings from the retrofit source for his tsi and put them on with ebay HID bulbs and we saw that they werent shining like they should they were very dim i pulled the bulb out just a tab and i got ten times brighter i told him to buy just the bulb but the real factory or replacement and they were fine it seemed that cheap aftermarkets that are sold are a little longer and at the point where the light was it wasnt focused properly but replacement OEM or in lamens terms the expensive bulbs are fine
Old May 4, 2010 | 08:48 PM
jefecito87's Avatar
Jefecito87
and i am not knocking cheap HID kits i have them on my fogs and high beams lol they work great but sometimes it worths spending the extra bucks lol for some stuff
Old May 5, 2010 | 09:08 AM
boostin4's Avatar
yes i have the base model (non-HID). the bulb length is distinctively different. it looks like im going to have to suck it up and buy a new kit from a reputable vendor.
Old May 5, 2010 | 12:10 PM
Aipex8's Avatar
X e p i A
The bulb length is going to be different. You are replacing your H7 headlight bulb with an HID bulb that has been mated to an H7 base. The HID is going to be thinner and longer. That's the nature of HID kits and the reason they are technically illegal for road use. The bulb shape will not match the optics of the housing or projector. All kits use the same bulb shape and mate that to all the different bases, so some are going to be further off than others.
Old May 5, 2010 | 02:15 PM
boostin4's Avatar
no the HID is shorter than the halogen bulb. not sure if its all h7 but the halogen looks like it has an extender on the back side. i had no issues with my other cars
Old May 5, 2010 | 06:24 PM
Aipex8's Avatar
X e p i A
Oh! There probably is a removable extender on the base of the H7 bulb that you will have to take off and put on the HID bulb. My g/f has a Mazda3 with halogens and I had to remove an extra plastic base piece and move it to the new replacement bulb when she had a bulb out. It was pretty hard to get off too, I wasn't sure if it was part of the bulb or not at first.
Old May 6, 2010 | 09:24 AM
boostin4's Avatar
ok cool. so something comes off the old bulb? ill try that then. thanks
stupid mazda lol
Old May 11, 2010 | 03:45 PM
boostin4's Avatar
the adapter from the halogen will not fit the hid base. does anybody have any pics of the hid bulbs or adapter kit
Evan Gray
Nov 24, 2015 01:00 AM
arexatemate
Oct 9, 2015 06:23 PM
wayloco
Sep 1, 2015 09:03 PM
