coilover install problems
Old Apr 16, 2010 | 03:13 AM
04rx's Avatar
just installed my ksport kontrol pro coilovers first off they were a pain second my ABS and Traction control light are now on! anybody know why? I unhooked the battery and they stay on! this is not my first install, But it is on my 8 i have done all three of my old hondas and never had any problems. all help would be appricated
Old Apr 16, 2010 | 06:00 AM
bse50's Avatar
#50
I'd check the abs sensors.
Old Apr 16, 2010 | 06:42 AM
Bigbacon's Avatar
2006 WB AT
i think for traction control you just turn the car to ACC or On, turn the wheel all the way to left then all the way to right and it goes off next time you turn it on.
Old Apr 16, 2010 | 07:27 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Jeez..........I can't believe it! Get a freakin manual and read it..........this car ain't no civic!
As Bacon eluded to...............everytime you disconnect the battery this is gonna happen. Turn the car to "On" but do not start. Turn wheel either way all the way, then all the way to the other side. Turn the key off. Next time you start it all will be normal. If they don't go off after you've done this, then you messed up something!
Old Apr 16, 2010 | 01:39 PM
04rx's Avatar
Tried turning the wheel did not work checked all sensors for the ABS they are all unharmed and have good connection also fuse for ABS is good. Anybody with any more ideas? i can not be the only person that has dealt with this? i am not an idiot when it comes to automotive mechanics and from what i know i did not mess with any thing other than the strut bolts and upper control arm bolts in front and sway and coltrol arm bolts in rear all ideas welcome thanks for all the help
Old Apr 16, 2010 | 04:16 PM
Mazurfer's Avatar
Well............if you followed what I wrote above and it didn't turn them off, then I would start looking at each connector at each wheel. I know you felt like you did this, but it's really all I can think of. As you said.........there shouldn't have been any compromise via pinching or stress involved to the ABS when doing the coilovers, but it's all I can think of for now. did you have trouble on one corner vs. the others? I'd start there if you did.
Also, while I said you can turn the wheel either way to begin with(and I think you can), I always turned the car on(don't start), then went all the way to the right and then all the way to the left. Then shut it off for at least a few seconds and started as normal. It's worth a try if you went to the left first???????
I'll see what else I think of besides maybe the connectors or wires, but can't think of anything else off hand. Unplug those connectors carefully and reconnect them.
Did you mess with the E-brake at all while doing the rear?
Old Apr 17, 2010 | 07:40 PM
04rx's Avatar
will try again as you stated but come to think my E-brake was on the entire time i had the car up both front and rear
Old Apr 17, 2010 | 07:44 PM
Grungepup's Avatar
Oilfield trash
all the way left (till it stops).... all the way right (till is stops), traction light will turn off but abs will stay on..... turn the key all the way to the off position (remove key), turn car on
if still on... pray
Old Apr 18, 2010 | 08:47 AM
Mazurfer's Avatar
if still on... pray
^.................FYI..............seen it work both ways. I've always gone to the right first.
Old Apr 18, 2010 | 10:50 AM
Grungepup's Avatar
Oilfield trash
yeah i know... but i was just trying to give him an exact picture of what to do
Old Apr 18, 2010 | 06:14 PM
04rx's Avatar
if still on... pray
Tried it twice today both ways traction light and ABS still on and i am praying! think a mazda dealer would be able to help me out?
xAgyex
Jun 3, 2026 03:47 PM
steve11711
Aug 22, 2015 11:11 AM
EfrainOlivares
Aug 14, 2015 06:17 PM
philip53
Jul 30, 2015 04:18 AM
Belalnabi
Jul 17, 2015 07:48 PM
