Front Camber?
Old Apr 9, 2010 | 10:33 PM
danrx8's Avatar
Front Camber?
all i could find in the front where the toe and caster adjusters but i cant seem to find the camber adjuster or bolt. i need help?? can anybody help me with pics?
Old Apr 9, 2010 | 11:08 PM
Toe is set on the rack tie rod ends...caster is the rear adjuster..vertical
In the middle..facing rearward..horizontally is the camber adjustment bolt
Old Apr 9, 2010 | 11:46 PM
danrx8's Avatar
and this is to adjust the camber in the front??cuz i adjusted the rear already i just need the front.
Old Apr 10, 2010 | 12:06 AM
Yes....Lube the bolt where the big flat washer enters the bushing as well...they get seized easily
Old Apr 10, 2010 | 12:30 AM
danrx8's Avatar
on the lower control arm?
Old Apr 10, 2010 | 12:32 AM
Yes...at the camber adjuster
There is no adjustment on the upper A-arms
Old Apr 10, 2010 | 12:38 AM
danrx8's Avatar
cuz i tried it and it makes the wheel stick out like if i was adjusting the toe
Old Apr 10, 2010 | 12:53 AM
danrx8's Avatar
this is not my car but is this where the camber bolt is at?
http://tinypic.com/r/zoi8vm/5
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Brokegang
Jan 3, 2016 12:45 PM
titaneum_grey
Sep 16, 2015 11:51 PM
