2010 SD Tour
Old Apr 8, 2010 | 12:29 PM
chiketkd's Avatar
Row faster, I hear banjos
2010 SD Tour
Looks to be very well-subscribed in many classes. Best of luck this weekend!
Entry List: http://ams.scca.com/netforum/eweb/dy...191d1&class=AM
Old Apr 8, 2010 | 01:21 PM
TopGear8's Avatar
mkuhnracing.com
Mark is registered with Hoosier's...Maybe somebody should tell him that they are not legal in STX..
Old Apr 8, 2010 | 09:11 PM
Wut, you didn't know about the new Hoosier 140TW ST tire?
Old Apr 8, 2010 | 09:20 PM
altiain's Avatar
Sparky!
Good luck Mark!
Old Apr 8, 2010 | 09:47 PM
mwood's Avatar
I saved us all from any chance of rain...
Bought some new rims and mounted up a set of Hoosier Wets
Jason, these ones are 36/08, not 01/01
Good luck to all, it should be fun...as SD always is!
Old Apr 9, 2010 | 12:33 AM
LOL. I'm basically unsorted/untested. It will take more than luck to walk away with anything but a butt whooping from Tom Berry
Old Apr 9, 2010 | 01:19 AM
mtellam's Avatar
Rotary Lover
Looks like we lucked out on the rain!
Old Apr 9, 2010 | 01:47 AM
Thanks for teh jinx
Old Apr 9, 2010 | 01:18 PM
pea soup fog driving in during the wee hoours
now 64 degF, clear sunny skies, light breeze
Old Apr 9, 2010 | 05:14 PM
chiketkd's Avatar
Looks like it'll be sunny and mid 60's all weekend. How did your car handle on the practice course today?
Old Apr 9, 2010 | 07:08 PM
It's wicked fast, but so much so that it has throttle oversteer. Boogered up the threads on one of the new wheel studs and by the time I found an M12 x 1.5 die and fixed it I had to rush to the practice course unprepared to buy tickets before they closed. It needed to have the front swaybar stiffened, but I didn't have the tools with me or the time to go back and get them. Pretty sure I can make the necssary adjustments to get it close for tomorrow.
The bigger issue is sound. I was right at the limit so threw on some turn downs that made the problem worse. After one run they were so hot there wasn't any way to get them off and no time to cool them. So potentially I may get DSQd on sound for the weekend. From what I heard everyone was running louder readings than normal so the wind may have blowing sound towards the station or other factors. I'm on my way to get some wire mesh, steel wool, and some clamps to see if I can stuff some steel wool into the outlet tips and then clamp the wire mesh over the end to keep it in place. I was going to buy a pair of clamp-on shorty Supertrapps from Summit Racing and now regret not doing so.
Old Apr 9, 2010 | 07:16 PM
And I'm on shaved Yokohama Advan AD08s. I think they're awesome tires!!!!
Old Apr 9, 2010 | 07:30 PM
chiketkd's Avatar
Good luck this weekend Mark. I've heard good things about the AD08's. Hope you can run close to Berry.
Old Apr 10, 2010 | 01:38 AM
mtellam's Avatar
Rotary Lover
"Yes, we're gonna have to go right to ludicrous speed."
Old Apr 10, 2010 | 01:35 PM
chiketkd's Avatar
Saturday Heat 1 results: http://www.scca.org/documents/resultfiles/results11.pdf
STR looks like a serious gun fight. Less than 2/10ths separate 1st through 5th place. Good mix of cars as well: S2000, MX-5, S2000, M Coupe, MX-5.
Old Apr 10, 2010 | 02:12 PM
altiain's Avatar
Sparky!
Plus at least four different tire compounds in that grouping, if the entry info is correct.
Old Apr 10, 2010 | 04:24 PM
StrokerAce's Avatar
STR is interesting. Top 5 in 0.2 seconds. s2k,mx5,mcoupe,mx5,mx5.
Old Apr 10, 2010 | 06:10 PM
GeorgeH's Avatar
Current results have Mark on top of STX, with Tom Berry in 2nd, but no times are posted.
Jason is on top in AS.
No RX-8s in the top positions for CS.
Old Apr 10, 2010 | 07:17 PM
Huh? I'm in my usual SD Tour position; last place, lol.
My only clean run was DSQ due to sound, but my big issue is power oversteer. The car has great acceleration, just can't keep the rear end under yet. Will try a few more things, but I'll probably need to order a stiffer center bar for the front sway for next weekend. Really expected understeer rather than oversteer, so it's a bit of a surprise.
Derek Punch is in 1st in a BMW with a Civic in 2nd. I think KJ is in the trophies in the only other RX-8 in STX this weekend.
Old Apr 10, 2010 | 07:43 PM
GeorgeH's Avatar
Oh well. Guess you can't trust the results until times are posted. I was rooting for you.
Old Apr 10, 2010 | 08:05 PM
chiketkd's Avatar
Day 1 results: http://www.scca.org/documents/resultfiles/results13.pdf
Old Apr 10, 2010 | 09:58 PM
TopGear8's Avatar
mkuhnracing.com
Mark, what were your sound readings?
Old Apr 10, 2010 | 11:00 PM
The 2nd run I was DSQd on was 93.5
The first run with the pot scrubbers stuufed in the tail pipes was low, but it killed the power, plus one side blew out the hardware mesh screen so I pulled it all off for that 2nd run
on the practice course I was pulling 93 - 93.5 with it open and 95 - 96 with the turndowns on it pointed at the ground. On my final run today I put the turndowns on with them pointed to the side away from the sound meter and was super low, below 80.
After talking to Jason after the event I'm going to wait and see what happens at El Toro before making any drastic changes to address the power oversteer issue. That site has a lot more grip than here.
Old Apr 10, 2010 | 11:51 PM
kjchristopher's Avatar
I'd second that. Today's SD course was looser than what I saw a month ago on this lot. El Toro two weeks ago was grippy enough to get my car pushy.
Old Apr 11, 2010 | 12:40 PM
altiain's Avatar
Sparky!
Man Mark, you really take the old "if you ain't first, you're last" to heart, don't you?
Better luck today!
