Fogs out
Old Apr 4, 2010 | 10:58 PM
EMart11b's Avatar
Bang Bang
Fogs out
Fuse is fine (swapped with horn fuse), bulbs are fine (tested on other car).... ideas?
Old Apr 4, 2010 | 11:16 PM
rodjonathan's Avatar
silent assasin
are you sure the fuse is ok? coz i ran into the issue once and i was checking the wrong fuse
Old Apr 5, 2010 | 02:26 PM
invasion08's Avatar
Double check and make sure you have the fog lights turned inside the car. You may have turned them off and didnt even now it.
Old Apr 5, 2010 | 04:27 PM
EMart11b's Avatar
Bang Bang
Unless there's a secret fog light button I don't know about that's not the case. I've tried every position on the twisty deal with no results.
I switched the horn fuse with it to see if it would work and it didn't, maybe the horn fuse isn't the same or something?
Old Apr 6, 2010 | 05:37 AM
Evilnissan's Avatar
Flip the fog light on and then flick your hi-beams on and off a few time and see what happens.
I have got to change out a busted lense and it looks to be a bitch.
vapor2
May 4, 2020 03:53 AM
RXFEVER
Aug 29, 2018 10:14 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
