calej729
03-23-2010, 11:39 PM
does the footwell kit sold on this site bring 4 tubes for both the front and under driver/passenger seat? if not can you buy the same kit to be used for the driver/passenger seat?
View Full Version : rotary fx led interior question? calej729 03-23-2010, 11:39 PM does the footwell kit sold on this site bring 4 tubes for both the front and under driver/passenger seat? if not can you buy the same kit to be used for the driver/passenger seat? WTBRotary! 03-23-2010, 11:40 PM no they are a 9 LED bulb for each footwell calej729 03-23-2010, 11:56 PM so to do the four sides the fronts and seats would require 4 kits? WTBRotary! 03-23-2010, 11:59 PM :confused: What? No the kit Rotary FX sells give you the footwell lights for both sides... on their website they will tell you what is included in the kit... RX8sd 03-24-2010, 12:03 AM no it's one kit....one LED bulb for each side and honestly it isn't worth the money in my opinon. I bought one like a month ago. Not happy with it what so ever. I ended up just using the bulbs for the doors instead ha ha. The instructions were kinda shitty too. You might have better luck with it though....just my two cents. calej729 03-24-2010, 12:03 AM ohh aight and are they bright? and does it include the turn on and off switch sorry for all the questions and thank you for the help WTBRotary! 03-24-2010, 12:09 AM ohh aight and are they bright? and does it include the turn on and off switch sorry for all the questions and thank you for the help Brightness depends on color, I had blue and they were bright but my friend had red and they werent as bright... the wires you wire it into are for the... Shit i just blanked :confused: ... um the switch that turns on the lights when you open, close or unlock your door, I forgot what its called again... calej729 03-24-2010, 12:11 AM ok yea i want red ones but i want it so that when i drive i can have led/neon lights where can i find that? WTBRotary! 03-24-2010, 12:14 AM you can wire it to a different harness where they turn on when your headlights are on... or you can wire it to a switch to turn it on and off... calej729 03-24-2010, 12:15 AM if this kit isnt good any idea where i can get the underglow kinda kit and the middle dome lights to red led? calej729 03-24-2010, 12:17 AM yea i want it so i can turn it on and off whenever is there any kind of harness or switch that i have to buy? WTBRotary! 03-24-2010, 12:21 AM Search... I cant give you all the anwsers... calej729 03-24-2010, 12:29 AM k tnx for the help |
