Painting my engine cover and sway bar
Old Mar 23, 2010 | 06:59 AM
littlenastymf5's Avatar
Im pretty sure theres a forum for this, Can anyone point me in that direction? I checked the DIY forums but didnt find anything so if u can just send me the link then that would be cool.
I wanted to paint my plastic engine cover and also wanted to paint my sway bar, both are to be painted red. Im pretty sure i have to use a sertnt type of high heat paint but im not really sure how to go about doing this or what kind of paint to buy. Thanks for the help its much appreciated.
Old Mar 23, 2010 | 09:08 PM
05shinka's Avatar
Bad Company, Till I Die
I did my sway bar a while back... Purple.. I thought it looked good with the Black Cherry...
Old Mar 24, 2010 | 10:34 AM
Thats hot, Did u just sand it down and spray over it? What kind of paint did u use
Old Mar 24, 2010 | 10:37 AM
Bigbacon's Avatar
2006 WB AT
I used caliper paint (Dupli-Color spray paint) on my engine cover and strut bar and it has held up perfectly.
you could probably use any high heat engine enamel I bet.
Old Mar 24, 2010 | 10:54 AM
Wow urs came out sick also. My ride is nordic green i was thinking about hooking up under the hood red and black. I got the red LEDs also
Old Mar 24, 2010 | 04:48 PM
05shinka's Avatar
Its call Multi-cast... made by duplicolor... got it at autozone... its a 2 phase paint. I sanded it to rough it up.. cleaned up all the dust.. then sprayed the first couple of coats which looks like a silver... let that dry completely.. then spayed the clear purple... the silver shines through... i thought it turned out pretty well...
Just take your time and add light coats a little at a time.
Solidtrance
22
Sep 4, 2015 12:47 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
MolecularConcept
Jul 26, 2015 09:09 PM
AussieGray
Jul 16, 2015 03:58 AM
