trunk lid button not working
Old Mar 23, 2010 | 03:12 AM
mopiko's Avatar
hi guys, My trunk lid button below my steering wheel is not working.
I tried opening the trunk lid using my remote key, does not work either.
Conclusion = i CANT open my trunk. What might be the issue? Shud i be sending it back to MAzda? Some connectors fused?
Please advise
Old Mar 23, 2010 | 03:34 AM
StealthTL's Avatar
Metatron
Did you disable it, in the glovebox?
The fuse is a 30 amp, marked "D.Lock"
S
Old Mar 23, 2010 | 04:29 AM
rotarykillz's Avatar
Rotary Freak
fyi there's a manual trunk open with your key in your passenger side tail light
but yes you probably hit the button in your glovebox by accident....I did the same thing a couple months ago and was pretty well freaked out
Old Mar 23, 2010 | 09:52 AM
mopiko's Avatar
THanks guys for the tip.
Ill check out my glovebox in abit, it is pouring outside.
Old Mar 23, 2010 | 09:53 AM
Vlaze's Avatar
The Angry Wheelchair
If your car is '06 or newer, you won't have such a button in the glovebox. It's only for '04-'05
Old Mar 23, 2010 | 09:27 PM
mopiko's Avatar
u guys were right. I knocked the glovebox trunk switch off.
THANKS!!
Old Mar 23, 2010 | 11:34 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Did you know that pressing the lock button twice will make the car go "Beep!"?
Old Mar 24, 2010 | 12:54 AM
WTBRotary!'s Avatar
Drummond Built
^^^ lol
Old Aug 7, 2010 | 11:46 PM
MidnightRaven's Avatar
im glad a thread like this existed i had the same problem :P
Old Sep 8, 2010 | 11:48 AM
chunbelievable's Avatar
Tetsumakysenpukyaku
Yes thank you very much for this thread. I apparently did the same thing. Why the hell was this button even put in the car?!?
Old Sep 8, 2010 | 12:22 PM
EDZRIDE's Avatar
2005 White GT
To prevent trunk entry when using the valet key.
Old Sep 8, 2010 | 12:24 PM
Vlaze's Avatar
Yea...and now for '06+ models all some a-hole has to do is smash your window and push the trunk release button under the dash and voila....your stash of hidden Asian hookers get to escape
Old Sep 8, 2010 | 12:25 PM
Tetsumakysenpukyaku
Oh... meh... I don't keep anything in my trunk other than my duster and compressor. I think I'm OK.
Old Sep 20, 2010 | 05:26 PM
ChillinRard's Avatar
ChillinRoD
AWESOME! IM glad this thread exists! I did tha same thing n freaked out, pushed a button n now its gud, thanks...
Old Sep 20, 2010 | 05:43 PM
Dirt_Nasty's Avatar
Filth in a world of Clean
YOU TOO? This happens way to freakin' often. Curse Mazda for allowing this. So many good hookers lost.
Seriously tho, why the hell didn't they continue this?
Old Sep 21, 2010 | 10:02 PM
pianoman-1's Avatar
Still stumped
My glove box button is in the right position. When I push my remote trunk button, or the release that's in the car, I hear a clicking at the spot of the release, but the trunk doesn't open. In the past, it would eventually pop open after many times, but now it won't at all. Any other theories?
Old Jun 18, 2011 | 11:07 AM
2kwik4u's Avatar
Just found this thread after a google search. Thanks for the tip. I never knew that button existed. I'm betting my buddy that was looking for change in the glove box the other day (to buy another White Castle Burger) saw it and thought it would be a funny joke.
+1 for another problem fixed!!
Old Feb 21, 2012 | 07:17 PM
Rotary-RX8's Avatar
Girls who drive stick FTW
sorry to bump such an old thread but i just had this problem happen to me . My car is an 06 so i dont have the switch in the glove box. I checked the fuse box below the steering wheel on the left and all the fuses seem to be fine (not blown) however there is ONE empty spot .. not sure if its supposed to be that way. Anyone know what else it could be ?? I dont want to pay mazda like 500 bucks to fix it
Old Aug 19, 2013 | 08:01 AM
06rx8nate's Avatar
Old Thread bump.
Rotary Rx-8, did you fix your problem??
Mine is also an 06, I started having a similar issue. The trunk release button inside the car works, but not on the fob (tried both fobs, no luck) and most annoyingly not on the little button at the back beside the license plate! Which I loved to use.. The fob works for locking and unlocking, alarm etc. but the trunk is being a bitch.
Old Aug 19, 2013 | 11:28 AM
EDZRIDE's Avatar
2005 White GT
Search the TSB sticky.
Old Oct 26, 2013 | 10:19 PM
sk8ersmg's Avatar
ik this was a while ago but i have the same problem right now. i have an o4 rx8 and the switch is on but i also hear a clicking noise when i use the key but nothing happens. Did you find a solution to this?
Old Oct 27, 2013 | 09:53 AM
pianoman-1's Avatar
I never came to a solution. I know for sure that power is reaching the trunk. I replaced several parts with working used parts and still had no luck. I gave up and moved on to other things. Hopefully I'll get back to it one day soon. It's a bit of a PITA with it not working.
Old Aug 3, 2014 | 12:51 AM
OnCam's Avatar
bump im having the same problem, no blown fuses & the valet button is in the correct position.. mine was somewhat intermittent where you would have to push it 2-3 times to activate the trunk release but then it stopped working all together.
there is the clicking noise when you push the trunk button below the dash & also does it when you press the release on the key fob.. have tried to see if any wiring is loose in the trunk area but all looks normal, nothing worn or been tampered with.
Old Nov 13, 2014 | 09:50 AM
drebbrnator's Avatar
Did anyone figure this out? My Rx-8 is having similar trouble.
I only have a valet key, so I can't manually open the trunk, and the electronics have failed.
The fuse is okay, but I don't hear a relay activate when I press the release button.
Old Nov 13, 2014 | 09:52 AM
logalinipoo's Avatar
Driving my unreliable rx8
did you check the switch in the glove box?
