SCCA re-class FD RX7 from ASP -> BSP. Email SCCA w/ member support.
Rating: Thread Rating: 14 votes, 5.00 average.
Old Mar 22, 2010 | 06:36 PM
s1mpsons's Avatar
SCCA is considering reclassifying the FD for solo racing in street prepared per the latest Fastrack... "The **** is seeking member input regarding a group of reclassifications which are currently in a preliminary evaluation
stage. These potential changes are as follows: - Move from ASP to BSP: Mazda RX7 (’93-’95)"
Please email the SEB with positive support so fellow FD owners can enjoy more competitive competition with stock twin turbo setups!!! Message should look like this:
"seb@scca.com
I support the consideration for reclassifying the 93-95 Mazda RX7 from ASP to BSP.
-Joe Smith
SCCA Member # 123456"
-Jake
Old Mar 22, 2010 | 07:23 PM
chiketkd's Avatar
Row faster, I hear banjos
This proposal has my support. I'll write my letter tonight. -Chike
Old Mar 23, 2010 | 10:45 AM
PedalFaster's Avatar
-Joe Smith
Letters in this format are minimally effective -- letters which present compelling, data-driven arguments in support of a change are far more so.
Old Mar 24, 2010 | 07:11 AM
s1mpsons's Avatar
Very true. My cookie cutter email was the minimum necessary to make your submission. I encourage everyone to site data points from actual fd asp times vs bsp times. Also site other comparable bsp cars (like Pontiac GXP, C4 Vette) that perform similar to the FD.
Old Mar 24, 2010 | 10:36 AM
Just out of curiosity, why can't the FD get it done in ASP? ASP still seems to be dominated by C5 Corvettes. An FD's considerably smaller and lighter than a Corvette, and although it would be down somewhat on power, SP-legal modifications should make up a significant part of the difference between the cars in stock form.
Am I missing some weakness in FD?
Old Mar 24, 2010 | 12:06 PM
chiketkd's Avatar
An FD RX-7 in SP trim will be around the same power & weight as a Solstice GXP. Both cars share a similar a-arm suspension design, and could run similar sized rubber. I see these cars being very close in SP trim, and the GXP was moved down from ASP to BSP within the last 2 years or so.
With regards to competitiveness, there's a thread on sccaforums which discussed the FD's competitiveness in ASP: http://sccaforum.com/forums/1/147565/ShowThread.aspx
McKee makes some great comments in the thread, and I've quoted a few below:
Originally Posted by boxboy
You can make 375ish rwhp on stock turbos at about 16psi. More boost than that and you are just generating heat. I'm not sure I'd go to huge tires since in ASP you'd be stuck with the stock 4.1 rear gear. With 285/18's (shortest big tire) and a 8500rpm redline you go 75mph in 2nd. Bigger tires would take you close to 80mph, which wouldn't be the best for off the corner grunt.
Not sure if the new rules would allow the wastegate to be ported. Creep is a problem at elevated boost levels and can make the turbo transition point abrupt.
Expect weight to be in the low-mid 2600's with SP rules. Competitive with a Z06? Probably some of the time, though I wouldn't want the stock gears.
-Andy
You should ask Dan Chadwick what he thinks after running his in ASP for awhile, and now prepping to SM2. Tire is not really the problem, gearing still is. I think a well prepped car could be competitive, but would be an A- car for the class. That's compared to a Z06. Given some of the other cars coming into the class like the S/C Elise, that might shift it down more.
Weight --- mid 2600's is reasonable to expect given ASP allowances. As mentioned, you need to run probably 5/8 of a tank or more of gas to avoid starve. That's a big deal when the tank is ~20gals. When I went to a 5gal fuel cell (legal in SM2), I figure I saved 100lbs of weight out of the car. Wheels and tires you will actually gain weight over a stock prepped car.
Power --- 350whp and 300tq is not unreasonable on stock turbos. I made in the 350-370whp range on bone stock turbos and motor, though it was not the most fun maintaining that system. Here's an old old link with some dyno sheets in it, including mine...http://www.siastuning.com/SMspecs.htm Note the power jump when the second turbo comes on, not the easiest thing to deal with.
Tires --- when I originally ran the car I was on 285's all around with the 4.33 rear gear (not legal in SP), and part of the reason for the 285's was keeping the gearing as short as possible. In retrospect, were I doing this again, I'd try taking the gearing hit and running a 315 in the rear just to try and make sure all the power was being used and grip through the corners was better (more speed maintenance).
All that said, when I ripped out all the vacuum lines and solenoids to put on a single turbo, that was a happy day.
-Andy M.
To answer the question on competitiveness, I'd think a full prepped car could be in the hunt sometimes, but I'd probably pick a S/C Elise or Z06 before it. I think that same car with short gears and some motor work would do better in SM2, relatively.
-Andy M.
Btw, here's the dyno of graph of McKee's RX-7 when his engine was still in ASP trim (undergoing conversion to SM2/SSM):
Link:http://www.siastuning.com/SMspecs.htm
Old Oct 27, 2011 | 08:29 AM
BRODA's Avatar
Not yet famous
Bump. This is happening (sort of).
http://www.scca.com:8080/assets/11-f...k-nov-solo.pdf
Old Oct 27, 2011 | 11:24 PM
chiketkd's Avatar
Just needs the approval of the BOD to make it a reality at this point.
If this goes through, the new ASP will be very interesting...
Old Oct 28, 2011 | 12:23 PM
dmitrik4's Avatar
please wait for the beep
time to start up the "RX-8 to DSP" drum again, Chike?
Old Oct 28, 2011 | 02:10 PM
kbrewmr2's Avatar
don't get me started on the *SP reorg
Old Oct 28, 2011 | 03:06 PM
dmitrik4's Avatar
don't go bringing your MR2 sob story here.
Old Oct 28, 2011 | 09:48 PM
chiketkd's Avatar
I'll let someone else beat that drum at this time...
I have a one-handed backhand that I'm developing into a weapon.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
chadsta
Sep 20, 2015 11:00 PM
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
Rupanrx
Sep 4, 2015 06:44 AM
You have already rated this thread Rating: Thread Rating: 14 votes, 5.00 average.
