19x9.5 & 19x10.5 +22 all around
Old Mar 17, 2010 | 01:29 PM
NoPistons4Chris's Avatar
Wondering on the fitment for these. I plan on running these with f)245/35/19 r)275/30/19. FYI my fenders are rolled already. I previously had 19x8.5 & 19x9.5 but my offset was + 35 and plus 38 and the car was lowered enough where the gap is basically flushed, or no tire gap.
Thanks guys!
Old Mar 17, 2010 | 01:46 PM
tbk's Avatar
tbk
ლ(ಠ益ಠლ)
you're gonna need a pretty good pull/camber to fit the rear. front should be fine with a roll i think
Old Mar 18, 2010 | 02:40 AM
tiltmode43's Avatar
OMGITM!
19x10.5 +22 w/275 is not going to be fun to fit. Technically, that setup is doable though...
Old Mar 18, 2010 | 08:35 AM
2tone's Avatar
The RX-8 is missed
yeah, if 18x9.5 +30 w/ 275's rubbed, i can only imagine what 19 / 10.5 +22 would be like. seems like a bit much for our cars...
and there is an entire thread dedicated to answering this very question...............................
Old Mar 18, 2010 | 12:44 PM
I like doable
I had 19x9.5 with 285's at one point with no rubbing issues and I was slammed as low as possible before.
Old Mar 18, 2010 | 12:49 PM
2tone's Avatar
The RX-8 is missed
hey, if you can do it, more power to you! at what offset was your set-up though?
edit: saw post #1...offset of +35 and/or +38. you're going an inch wider in rim size, and pushing them out 12 to 15 mm, so, yeah, it would be tight.
Old Apr 10, 2010 | 06:03 PM
StealthFox's Avatar
if tilt is suggesting a difficult situation, i would follow that, he's fit some retarded wide/low offset wheels on his rx8. other than that im my opion go for it! thats the exact fitment i want to try so you can be the test guinea pig!! i hope fender rolling and a little neg camber will do the trick. and it wont pop the sidemarkers out :'(
Old Apr 10, 2010 | 06:25 PM
Fate710's Avatar
Super Low & Super Slow
I'm already gona call this. PULL = 150% yes required I don't give a **** how much camber you run.
Camber department you are probably looking at -3.5* at least if you plan to run that big of a tire
Old Jul 26, 2010 | 02:04 PM
urbanlegendrx8's Avatar
Up, Up & Awayyy!!!
So did you end up getting it to fit with the 19x9.5 & 19x10.5 set up??? Reason I ask is I'm thinking of getting a set of 18X9.5 for the front and 19X10 for the back...offset i'm not sure yet...gotta get ahold of the seller. They are enkei RPF1 fyi.
Old Dec 25, 2014 | 12:44 AM
Alex37's Avatar
Rx8 04
Hi .. What about 19x9.5 and 19x10.5 rims with tires 225 35 19 and 265 35 19 fit ? On the rx8 04 automatic transmission ??? Thank you guys for replay me and infor me ...
Old Dec 25, 2014 | 01:03 AM
Alex37's Avatar
Rx8
What do you mean ? The tires 265/35/19
225/35/19
Not fit on the rx8 ?
Cuz I ready have the rims not monten yet ... But I need some tires for the rims I want wide tire on the back ...help 🙏
ray_7
66
Jul 9, 2006 09:20 PM
donald121
May 13, 2006 04:44 PM
ToguePirate787
Nov 13, 2005 06:58 PM
success07
Mar 13, 2005 05:02 PM
