Fixed everything but this !!!!!
Old Mar 11, 2010 | 05:54 PM
Mr.We$t's Avatar
Rx-8 the protege
Ok so this winter I've let the car sit for awhile and decided to make some changes!!!
The engine flooded once and I deflooded it found oil in the intake cleared it out and cleaned the MAF sensor and put in a new intake!
The only problem i'm having now is that when the car is in idle it sounds like the power dips Or the idle slows down then jumps back up also there sounds like a growling or gurglin in the engine!
Changes I've made:
battery (with new connectors)
plugs
wire
engine mounts
mid-pipe
AEM intake
Old Mar 12, 2010 | 12:20 PM
Mr.We$t's Avatar
Rx-8 the protege
Talking
Bump
Old Mar 12, 2010 | 12:47 PM
Huey52's Avatar
Registered Zoom Zoomer
"marbles in a can" (MIAC) sound?
Old Mar 12, 2010 | 04:50 PM
DeViLbOi's Avatar
The devil made me do it
How many drive cycles have you done since the battery change? Have you swapped back to the OEM intake box? Have you checked for vacuum leaks? Which intake did you go with? How low do the RPMs drop to?
Old Mar 12, 2010 | 05:23 PM
Mr.We$t's Avatar
Rx-8 the protege
Red face
Not sure what the drive cycles but since I changed the battery I've driven it 2 times
I have an aem in take (used to have the k&n typhoon 2)
It's sounds like the car is shutting down then it jumps back up
when I start it the RPM jump to 2k then drop immidiatly back to 0
Old Mar 12, 2010 | 05:35 PM
DeViLbOi's Avatar
Just need more drive cycles.
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
kody59
Sep 28, 2015 03:43 PM
drlubell
Sep 26, 2015 11:58 PM
