my 8 wont start?
Old Mar 11, 2010 | 07:54 AM
isLoTz's Avatar
bente doz
my 8 wont start?
okie, here it is..
idk exactly what happened
it juz wont start at all...
no honk, my keys no function, no lights anywhere..
any clue guys to fix this?
Old Mar 11, 2010 | 07:55 AM
Jon316G's Avatar
Grasshopper
have the battery tested
Old Mar 11, 2010 | 07:58 AM
isLoTz's Avatar
bente doz
i did already,..
still the same..
Old Mar 11, 2010 | 09:32 AM
isLoTz's Avatar
bente doz
no help?
Old Mar 11, 2010 | 09:41 AM
invasion08's Avatar
What was the battery voltage when you tested it? Also is it a MT, if so, push start it.
Old Mar 11, 2010 | 10:29 AM
isLoTz's Avatar
bente doz
i didnt check the battery voltage
it is MT, idk how to push start, or maybe im doing it in a wrong way?
how it is shud be?
this is what happend, i didnt use my car for 5days coz i've been sick for like 1 1/2 weeks and then early in the morning i was on my way to work, suddenly i unlock my car nothing happens, so i used my key manually to open my door..no lights, no honk, nothin at all..
so yeah..
Old Mar 11, 2010 | 10:42 AM
invasion08's Avatar
Then how to you know your battery is good?
Instructions
Step 1 Make sure that the problem is either the battery or the starter: If the engine cranks ("rrr-rrr-rrr") when you turn the key, then the problem isn't the starter or the battery.
Step 2 Plan to have at least one person sitting in the driver's seat and one person pushing. Mid-size and large cars require two or three people to push, depending on the strength of the people and whether or not the car is parked on an incline.
Step 3 Turn off all accessories (radio, wipers, lamps).
Step 4 Turn the key to the "on" position.
Step 5 Depress the clutch pedal with your foot.
Step 6 Put the transmission in second gear.
Step 7 Release the hand brake and the foot brake.
Step 8 Note that the people pushing need to get the car rolling as fast as they can. This works best down a hill or an incline.
Step 9 Release the clutch pedal while giving the engine a little gas with the gas pedal once the car is moving about as fast as you can run. The engine should start.
How old is your battery? Or if you do not feel like push starting it borrow a car and get a new battery.
Old Mar 11, 2010 | 10:46 AM
isLoTz's Avatar
bente doz
i have no time to check it in the morning coz i was late at work already,
but for sure when i get off at work..ill do that,,..thanks for the input..
ill get back if everything is O K
Old Mar 11, 2010 | 12:17 PM
jasonrxeight's Avatar
or get it jump started, how hard can it be?
Old Mar 11, 2010 | 02:15 PM
prighello's Avatar
No electricity = dead battery 99% of the time.
Old Mar 11, 2010 | 04:29 PM
isLoTz's Avatar
bente doz
in using battery, it shud be the exact model or something?
like the manual said 12V-52AH/5HR?
Old Mar 11, 2010 | 04:31 PM
invasion08's Avatar
Did you try hooking jumper cables up to it?
Old Mar 11, 2010 | 09:28 PM
rxwarrior's Avatar
I would try cleaning any corrosion off the battery posts and clamps first. Then put the battery on a charger or try jump starting. My car didn't start today and I was almost late for work. The negative post was corroded on top of being a little loose. I moved it around a little and the car started, got to work on time and then after my shift I had to do it again. I got home, cleaned them up real good and tightened them up. No more problems.
Old Mar 11, 2010 | 09:37 PM
mkmike103's Avatar
Clean terminals, recheck. Probably need a new battery though.
Old Mar 12, 2010 | 08:22 AM
isLoTz's Avatar
bente doz
well probably i need a new battery..
does it matter if u left ur trunk open?
maybe that's the reason why my car didnt start up for 5 days,.( it's just a thought )
yah i did try jumped starting on it but not by car to car..it didnt work as well
so if it is the battery
what do you guys recommend?.
Old Mar 12, 2010 | 09:06 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
If your trunk is open than your trunk light was on. . . thus draining the battery.
When you tried to jump start the car. . . what did it do? Anything? Lights worked? Horn worked? Interior kicked on when the key was turned to on?
If jumping it didn't work, its going to more than just your battery, but I'm still betting that's it first.
Old Mar 12, 2010 | 09:11 AM
isLoTz's Avatar
bente doz
nada - nothing my friend
even my key is not working at all
so battery dead? or does it need to be recharge?
Old Mar 12, 2010 | 09:14 AM
Huey52's Avatar
Registered Zoom Zoomer
Yep, the trunk light will drain your battery overnight.
After deep drainage a standard battery may not take a charge if it was marginal to begin with. You can bring it to a battery shop and have them check its capacity.
Old Mar 12, 2010 | 09:18 AM
isLoTz's Avatar
bente doz
awts that's too bad then,..
so i guess i have to buy a new 1
Old Mar 12, 2010 | 09:20 AM
Vyndictive's Avatar
Well, wait a moment. . . you said you tried to jump start it... if you did this correctly and your battery connections are good, your car would have gotten power.
You're saying that this didn't happen, correct? You hooked up the jumper cables and nothing at all happened. . . ??
Old Mar 12, 2010 | 09:25 AM
isLoTz's Avatar
bente doz
yap like totally nothing happen..
no spark, no click click click, no honk, no lights anywhere..key not working too
may be later or tomorrow i'ma try jump start it again using car to car
and hopefully it will fix my car
Old Mar 12, 2010 | 09:26 AM
SheffieldSteel's Avatar
Intended acceleration
Main fuse?
Old Mar 12, 2010 | 09:34 AM
isLoTz's Avatar
bente doz
Originally Posted by SheffieldSteel
Main fuse?
doubt it
Old Mar 12, 2010 | 09:46 AM
CTrx8's Avatar
space for rent
so you said you tried to jump it but not car to car? what did you do?
Old Mar 12, 2010 | 10:15 AM
isLoTz's Avatar
bente doz
yeah its like using cigarette lighter, idk what do you call it
