Question About Cat Replacement
Old Mar 9, 2010 | 06:43 PM
Icky Mettle's Avatar
So, over the past couple of weeks I began to suspect my cat was failing. I noticed a small drop in power in the mid to upper RPM ranges, my fuel consumption had gotten noticeably worse, and occasionally I'd have a few small exhaust shudders under low throttle. I had been keeping an eye on it, looking under the car to check if it was cherried after driving, but a visual inspection revealed nothing out of the ordinary. Yesterday I finally got a CEL on my way to work and made an appointment with the dealer. Sure enough, the cat was operating below threshold - no surprise there. Surprisingly, the dealer had a cat in stock and my car was ready for pick-up in about two hours. Now, here's my question...
I just got the car back and took a quick look underneath after the drive home, which is only about a 15 mile commute from the dealer. Crouching down and looking from the driver's side, there's a small circle where the air sensor plugs into the cat that was glowing red. It also seemed exceptionally hot, much hotter than the one I just had replaced. Naturally it smells terrible, but I'm assuming that's from the anti-corrosive aluminum/zinc powder that most new exhaust components are coated in. I've only owned the car for about 5 months and it has nearly 50,000 miles on it, so I don't really have a good point of reference for "normal" cat behavior since I apparently bought it with a half-dead cat. So I guess my question would be...is the small glowing circle normal or was my old cat so far gone that it wasn't even operating at the correct temperature? Should I be alarmed, or am I worried about nothing?
A little history on the car: Stock 2004 GT 6MT, only one previous owner with pristine service records, all recalls performed, original engine still pulling strong with plugs and coils replaced at 45,000 miles.
Old Mar 23, 2010 | 08:18 AM
mat128's Avatar
I was wondering the same thing. I got my RX8 out of storage yesterday, I used it all day and it pulls much better than ever (new coils, old were long gone and dealer only said 1 was bad... changed all 4).
I got home yesterday at night and decided to take a look at my cat (by leaning on the ground) and I saw exactly what you describe, glowing red hot right around the O2 sensor. I have less than 25k miles on it but I ran with bad coils during the end of last summer. I am really wondering if my cat is blocked (possibly melted from running on bad coils?). The car runs wonderful and pulls a lot more than last summer so I guess exhaust isn't blocked (or partly).
I guess the catalytic converter is part of a longer warranty, since it's a pollution control device?!
I hope people here can confirm our problem or standard behavior!
Old Mar 25, 2010 | 08:50 AM
mat128's Avatar
bump... also OP, you could change the title to "red hot cat" to catch the eye
mr. GrandGame
Sep 9, 2025 10:41 PM
tbiggybig
Aug 13, 2016 06:30 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
dbarber
Jul 25, 2015 01:34 PM
Jvswan
28
Jul 23, 2015 09:02 AM
