morganrogers
01-15-2003, 07:32 AM
Not my own work - found in main forum but could this be true ?
I cannot find anything on rx8 website for on-line ordering or £1000 deposit ....
MAZDA RX-8 UK PRICING AND SPECIFICATIONS ANNOUNCED
On-line Pre-order Facility Available
Detroit Motor Show 2003 was the venue for the first appearance of the production model of Mazda's eagerly awaited RX-8 rotary powered four-seater sports car. With the world launch of the Mazda RX-8 at Laguna Seca immediately following the Detroit Motor Show, Mazda has announced UK pricing and an on-line pre-order facility.
In line with Mazda's philosophy of offering outstanding value in cars that are fun to drive, the UK pricing of the Mazda RX-8 is extremely attractive. The low power version - 192PS - is priced at just -19,995 and the high power - 240PS - UK21,995 with both versions going on sale from the end of July.
The Mazda RX-8 has been designed with both fun and functionality in mind. With a rigid chassis, sports suspension, six-speed transmission on the high power version, coupe styling, class leading handling, steering and braking and the unique and powerful Mazda rotary engine, it is a pure high performance sports car designed to be enjoyed by enthusiastic drivers. Conversely, with its freestyle rear door system allowing an ease of access to the rear two seats not found in traditional coupes, sufficient room in the rear for generously proportioned adults and a boot that allows for a realistic amount of luggage, the Mazda RX-8 eliminates the compromises normally associated with sports cars.
As with all Mazdas the RX-8 will be very well specified as standard with both models featuring 18" alloy wheels, ABS with EBD, DSC with TCS, driver, passenger, side and curtain airbags, climate control air conditioning and a BOSE
Premium Audio Sound System with nine speakers and a six CD auto-changer.
Already there is considerable demand for the Mazda RX-8 and with limited production available to the UK market and its highly attractive pricing, Mazda has established an on-line pre-ordering facility which will enable customers to get to the front of the queue. The on-line system will be available from mid February.
To pre-order a Mazda RX-8 customers need to access the secure web site www.mazdaRX8.co.uk where they can place a deposit of £1,000 via credit card, thus securing a vehicle, which will then be allocated to the dealer of their choice.
The benefits to the consumer are that they are much more likely to acquire the vehicle of their choice, be the first to receive news and details on the vehicle, some of which will be exclusive, and also be eligible for special programmes that are currently being devised for the first customers to place deposits. Specific terms and conditions will apply to this process.
ends…
Mazda RX-8 UK Prices & Key Specification
-----------------------------Low Power-----------------High Power
Engine-------------1308cc Twin Rotary-----------------1308cc Twin Rotary
Transmission------------5 Speed Manual-----------------6 Speed Manual
Key Features
ABS Brakes with 17"----------------YES-----------------YES
discs and EBD
Driver, passenger ----------------- YES-------------------YES
side & curtain airbags
DSC and TCS ------------------------YES-------------------YES
18" Alloy wheels---------------------YES------------------YES
Front fog lamps----------------------YES------------------YES
Climate control AC------------------YES------------------YES
BOSE premium audio-----------------YES-----------------YES
sound system/9 speakers/
6 CD auto-changer
Xenon gas discharge headlamps ----- NO ----------------- YES
Alloy pedal set------------------------ NO--------------------YES
On the road RRP-----------------UK 19,995------------ UK 21,995
Available Options
Metallic paint
UK300
Electric slide & tilt sunroof
UK500
Leather seats powered & heated
UK1,200
Satellite navigation
UK1,500
Engine details
Displacement
1308cc twin-chamber rotary
Maximum output
240 PS (high power)
192PS (low power)
Maximum torque
211 Nm at 5,500 rpm (high power)
220 Nm at 5,000 rpm (low power)
Transmission
Manual gearbox
5 speed (low power)
6 speed (high power)
Prop-shaft
Carbon composite
Differential
Rear-mounted limited-slip
Dimensions
Length
4,435 mm
Wheelbase
2,700 mm
Width
1,771 mm
Height
1,340 mm
Weight
1,300 kg[B][U]
PS. UK is not USD. Change rate is about 1.6
So 1 000 UK = 1 600 USD
United Kingdom is very expensive country.
So i think price on rx-8 in other countries of Europe will be like in the USA
ends…
Key Features
discs and EBD
6 CD auto-changer
Available Options
Metallic paint
UK300
UK500
UK1,200
UK1,500
Engine details
Displacement
Maximum output
240 PS (high power)
192PS (low power)
Maximum torque
Transmission
Manual gearbox
5 speed (low power)
Prop-shaft
Carbon composite
Differential
Dimensions
Length
4,435 mm
Wheelbase
2,700 mm
Width
1,771 mm
Height
1,340 mm
Weight
1,300 kg[B][U]
