transmission or clutch?????????????
Old Mar 8, 2010 | 01:44 PM
danysrx8's Avatar
CA transmission or clutch?????????????
so this weekend i went with the same mechanic that i isntalled my clutch with and i told him that there was a weird noise everytime i pressed the clutch pedal, the noise comes from the bottom of the car not inside. so at first he tells me oh yeah that noise is because your clutch pedal is broken which by the way i need to take off an solder, but anyways i tell him that its messed since before he intalled the new clutch which is a stage 3 from f1 racing i bought it on ebay,the only thing is i did not buy a flywheel they intalled it with my original flywheel. so i turned on the car infront of him, because u can only hear the wierd noise when the car is on, an as soon as i turned it on he heard the noise and he said oh yeah thats gonna be transmission problems we are going to have to rebuild most likely he said.
the noise that i hear is like a rubbing kind of vibrating sound
help please
Old Mar 8, 2010 | 01:49 PM
Jon316G's Avatar
Grasshopper
Stage 3? That might be a little overkill....
Anyway, noise when you press the clutch pedal in could be the release bearing.
Problem is you have to drop the transmission in order to inspect it.
Old Mar 8, 2010 | 02:15 PM
danysrx8's Avatar
if it does happen to be that what do you think they might charge to fix that and do you think he is right by saying they have to rebuild it
Old Mar 8, 2010 | 02:20 PM
Jon316G's Avatar
Grasshopper
A release bearing is about a $50 part, so you'll pay that + labor.
The bearings sits on the spline in the bell housing, so you don't need to disassemble the transmission.
Old Mar 8, 2010 | 02:26 PM
danysrx8's Avatar
ok thanks alot u have been very helpfull
Old Mar 13, 2010 | 01:42 AM
Wren's Avatar
Im sorry to tell you this but I had the same problem and when i push in the clutch pedal the noise goes away.If this is the same as yours Ive been told it is probably the front bearing in the gearbox which is infinatly more expensive hence why I havent done it yet.6 months along its still going strong so good luck
Old Mar 13, 2010 | 01:49 AM
search gear rollover. normal.
Old Mar 13, 2010 | 03:09 AM
shaunv74's Avatar
Power!!
+1 noise when clutch in = throwout bearing. Which your mechanic should have replaced when he replaced your clutch if he was halfway knowledgeable.
Noise when clutch out=normal
Also: Broken clutch pedal is possible. Solder is not an acceptable fix for the clutch pedal bracket. It needs to be welded.
Old Mar 13, 2010 | 03:32 AM
bse50's Avatar
#50
IMO, the OP would have complained about difficult shifting/grinding if that were the case. Is it yet accepted as a consensus that the clutch pedals should always be remedied, somehow, as a worthwhile precaution just the same?
Especially since it's a cheap fix that prevents other serious problems such as premature clutch and trasmission wear.
i still shiver w hen i come to think that i had to replace a transmission and a clutch for a stupid pedal that was not even broken, just flexing.
Old Mar 13, 2010 | 07:15 AM
bd32322's Avatar
yeah mine had the same problem and it was the throwout bearing.
My clutch was worn out too - so dealer replaced clutch too - but the noise came back within 1000 miles.
So they replaced the throwout bearing again - and now after 2000 miles the noise is back again - what the heck? Very weird.
Old Mar 13, 2010 | 08:18 PM
shaunv74's Avatar
Power!!
That's two products I know of now where shitty seems to always proceed Koyo. Hmm...
Old Mar 14, 2010 | 11:17 AM
E.M.S.'s Avatar
Stupidity keeps me busy!!
i think he means radiator. i know they build some great stuff for some vehicles/uses but i haven't heard a good thing about their radiator for the RX8
Old Mar 15, 2010 | 02:04 AM
shaunv74's Avatar
Power!!
What's the other one?
Ray I'm thinking you should make a business plan on watching what Koyo makes and just go behind them and make a replacement product that actually works. You are 2 for 2 so far.
Old Mar 15, 2010 | 11:54 AM
danysrx8's Avatar
so a quick update. just last night i told my wife's dad to help me bring the transmission down to change the collar bearing. well this morning the noise all of a sudden has decreased i could barely hear it now but i mean its still there should i just go ahead and change it anyways
Old Mar 18, 2010 | 01:40 AM
kinda lost me now..
maybe some photos.. and let us know how it turns out..
Old Mar 18, 2010 | 01:44 AM
shaunv74's Avatar
Power!!
The idea that their radiator for the RX-8 is ineffective as an upgrade is kinda funny because they make the OEM unit. Koyo/Calsonic makes it, so I would have thought Koyo to have a firm grasp on the shortcomings but perhaps not.
I guess not everyone is AEM or Borla.
Old Mar 18, 2010 | 01:48 AM
Huh,
aem / borla.
rads? hp might be made in exhausts. not so much in rads.. so no proof in the claims..
Old Apr 6, 2010 | 01:22 AM
g0rdhan's Avatar
i have the same issue, i took it to the dealer and he said it sounded like a loose bearing? transmission bearing??
anyone have any thoughts??
Old Apr 7, 2010 | 01:34 AM
shaunv74's Avatar
Power!!
Originally Posted by swoope
Huh,
aem / borla.
Meaning they actually make OEM components for Mazdaspeed as well as aftermarket but unlike Koyo they work well.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
