View Full Version : Custom JL Audio 10W7 w/ JL HD Amps Install
jpav123
03-06-2010, 06:15 PM
I just wanted to show my new custom install in my 8. I hope this help those who are thinking about a custom install and can give them some ideas. The folks down at Bluegrass Audio in Bowling Green Kentucky did the install. Barry is the owner and a really great dude. I've included their FB page below. Any thoughts or comments are appreciated and no I don't care about the weight it adds.
http://www.facebook.com/#!/pages/Bowling-Green-KY/Bluegrass-Audio-Security-LLC/161505276020?ref=ts
Here's what I have installed:
Metra Double Din Kit
Boston Acoustic Pro 6.5 SE
Boston Acoustic SL 95 6x9
Eclipse AVN 6620
Eclipse IPC 106: Ipod
Eclipse BEC 108: Back Up Camera
Eclipse BT600: Bluetooth
Audio Control LC6i
JL Audio HD 750/1 x 2
JL Audio HD 640/4
JL Audio 10W7 x 2
Stinger Wire
Stinger Power Series 680 Amp Secondary Battery
Optima Red Top Battery
JL Audio RCAs
Ohio Generator 180 Amp Alternator
sw-ontarioguy
03-06-2010, 08:01 PM
Clean set up man. You kinda lost functionality in you trunk, but realistically, our trunk isn't very functional in the first place. I like it, it just isn't for me, I like being able to put very little into my trunk lol. Grats on the clean set up tho
nx04
03-07-2010, 09:08 AM
nice man looks really clean
w7 must hit like a mofo
van
03-24-2010, 06:56 PM
Looks good. I'm thinking about adding an aftermarket double-din deck as well. Do you loose functionality of the red LED display above the HU? Are you able to set the clock? Also how about the steering wheel controls?
jpav123
03-30-2010, 08:22 PM
I have functionality of the display along with controlling time. It also shows the amp temp too. I don't recall the name of the unit I used to retain steering wheel controls, but works ok.
van
04-07-2010, 12:57 AM
How where you able to maintain the functionality of the display? (set clock/track info) Is there a device from the metra kit that controls it?
jpav123
05-26-2010, 05:59 PM
It's controlled with the center ac switch. You toggle through your options after you hold down the center circular ac button. You sue the defrost buttons to cycle through the options.
bhammer
05-26-2010, 11:41 PM
What kit or hardware did your installer use to be able to do that?
laythor
05-26-2010, 11:59 PM
it's the metra kit
bhammer
05-27-2010, 12:10 AM
it's the metra kit
Unless Metra has added something in the last month for the S2, it isn't the metra kit. I spoke with them about 3 weeks ago and they said that they have a y cable that way you can plug in your factory radio to change the clock and that I would lose the center section of the display as it would be off. unless the OP is using an S1 kit with his S2.
