Where to run iPod Cable
Old Mar 5, 2010 | 12:56 PM
TheWulf's Avatar
My 8 looks like a Smurf
You can easily do that but you'd have to dremel a hole for it.
Mine goes in the cup holder. No eating or drinking in my car, hence no problem.
Old Mar 5, 2010 | 01:13 PM
Mr.We$t's Avatar
Rx-8 the protege
+1^ did the same with the grom plug. There Is a little plastic piece in the cup holder that pops out I ran the wire through there and it works perfect and doest look bad
Old Mar 5, 2010 | 01:31 PM
Easy_E1's Avatar
I put mine in the compartment behind the cup holder. Same scenario as Mr. West.
Old Mar 5, 2010 | 01:39 PM
Alexb's Avatar
desperately needs a drop
If you are worried about a hole in that compartment, drill through that little piece the cigarette lighter is connected to. you can buy those individually for like $12. So if you get rid of it, or sell the car, you can easily replace it.
Old Mar 5, 2010 | 01:59 PM
ninjajim4's Avatar
you don't have to drill or dremel anything to have it in the compartment behind the cup holder. just pull out the panel for the cigarette plug, like alexb was saying, and then run the cable right in at the corner and just have it squeezed between the panel and the console. it won't sit flush at the bottom edge, but when you put the little felt liner back on, it looks flawless. i did this with my mini usb for hooking up phone, external drive, etc to the carPC
Old Mar 11, 2010 | 09:59 AM
JLknights61's Avatar
When I had my audiolink i ran it into the console compartment and went down the left side opposite of the ebrake. It was in there for about 8 months when I removed it no damage to the cable. As ninjajim4 suggested I also ran my cable under the cigarette lighter so I had to do no drilling.
Old Mar 11, 2010 | 11:51 AM
JessiahC's Avatar
Nitrous Threadjacker
I had to go to with the bluetooth xcarlink, cause I hate cables everywhere!
Old Mar 11, 2010 | 01:17 PM
laythor's Avatar
I zoom therefore I am.
i ran my ipod into my glove box. with my avic d3x i can control everything from the HU so being able to see the ipod is pointless.
Only time i even touch the ipod these days is to watch a movie since you can't control movies with the d3.
Old Mar 12, 2010 | 10:13 AM
laythor's Avatar
mines on the A pillar coming out of the gap between the pillar cover and the roof liner. havent had any issues
Old May 20, 2011 | 11:02 AM
Lancifer's Avatar
Lead Foot
Back from the dead... but only to answer this question as I could not find the answer during installation yesterday. I actually mounted my mic ON the center console behind the shifter. It is a little awkward but it works very well. The way it is now I ran the cable under like normal but there is a slight space I was able to leave the mic coming out of. Sure when I snapped the console back down it slightly crunches the cable but it works for now until I actually go in and use a dremel to mount the Mic right into the center console.
I'll post a pic tonight.
[edit] Meh I will post a pic of where it is anyway... but I have a hand resting habit thats hard to break. Will probably take it back apart tonight or tomorrow and maybe mount the mic on the steering column. We shall see.
Old May 21, 2011 | 11:26 PM
Lancifer's Avatar
Lead Foot
I just re-ran the wiring today. Forgot about taking a pic. But now the mic is mounted on my steering column. Sounds better even. Ran the iPod cable under the center console and out through the rear lighter access door. Funny enough the door is flexible enough to put down over the iPod cable. Put Velcro under the felt pad and ran the cable under it with the connector showing. Not a bad setup, although the grom mic is kinda huge.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
