View Full Version : Redline's new pipes.. Word..
Redline Cowboy 03-04-2010, 09:52 PM some pictures of the pipe set up.. I'll get the others on here soon.. It seems its so loud without some sort of muffler its brain killing.. so I have new glass packs in the rear.. sound is perfect.. I'll get shots and maybe a vid of the goodies.
rodjonathan 03-04-2010, 10:02 PM pretty sweet mind posting a sound clip?
Fate710 03-05-2010, 01:08 AM Welding could be a bit better and mandrel bent over crush bent any day. Other than that looks good.
I'm getting ready to do the same thing in a pure 3" variety. Local guy is gona do a 3" Y off the back pipe into two 3" outlets.
altspace 03-05-2010, 05:42 AM Welding could be a bit better and mandrel bent over crush bent any day.
+1. Props for wanting custom, but I'd be concerned of that welding work in the Y split. I'm no expert by any means, but it just looks like mush between the pipes.
paulmasoner 03-05-2010, 06:13 AM i hope you did that yourself. if someone took money from you for that, they should be shot
Fate710 03-05-2010, 01:16 PM +1. Props for wanting custom, but I'd be concerned of that welding work in the Y split. I'm no expert by any means, but it just looks like mush between the pipes.
Just to go a little furhter on what Alt was saying, there are companies that sell y-pipes for around 20-30 dollars that coming in everything from aluminized to stainless steel.
I know personally I got mine from Magnaflow and its a 3" in and dual 3" out piece and its a really nice piece.
KrumbZ 03-05-2010, 01:37 PM u should get this Y pipe
http://www.bodykits4me.com/images/products/products/p_MAG-10798.jpg
Easy_E1 03-05-2010, 01:38 PM I'm sorry dude but that is looking a bit rough.
Redline Cowboy 03-17-2010, 06:41 PM older vid.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/EPXCcX8k2uA&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/EPXCcX8k2uA&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
laythor 03-17-2010, 06:45 PM lol.. you went straight pipe on the 8? could've saved youself some money and put "i have a 9 year old tied up in my trunk" painted on the side of your car... would get pulled over just as many times.
i kid, i kid. I'm sure the unmuffled sounds was pretty nasty, might think about putting a resonator in there.
Redline Cowboy 03-17-2010, 06:46 PM fresh pics of the pipes after a little bit of work with them.. but the sound is 100% better.. I'm working on the vid now.. so.. Soon I'll have it up..
Redline Cowboy 03-17-2010, 07:07 PM lol.. you went straight pipe on the 8? could've saved youself some money and put "i have a 9 year old tied up in my trunk" painted on the side of your car... would get pulled over just as many times.
very true .. I did however go back and fix the sound.. And its not a straight pipe its a Agency Power Dual res mid pipe with a custom Y pipe split. Now it has twin glass packs for sound deadining.. sounds perfect now.. But I will change out the Y as soon as I can for a real split y so its not so ugly.. but its homemade..
9krpmrx8 03-17-2010, 10:34 PM Where did you get the glasspacks?
Redline Cowboy 03-18-2010, 12:27 AM some local muffler shop.. they arent any name brand.. that i know of but they look like magnaflow style.
9krpmrx8 03-18-2010, 12:28 AM Oh, I thought glasspacks were a brand.
altspace 03-18-2010, 08:02 AM A.K.A - Cherrybomb
L337fpc 03-18-2010, 08:07 AM I've burned out all of the fiberglass in my Greddy SP2...and my idle is almost the same as yours...just a few decibels lower. Ever notice when you let 2nd gear slow you down...that it almost sounds ported?
Those glasspacks will burn out in a few months, they just can't take the heat of the rotary. Atleast you didn't spend a whole lot on the setup.
9krpmrx8 03-18-2010, 10:14 AM I heard a FC with Cherry Bombs and it sounded sick.
