Experiment: O2 SIM
Old Mar 4, 2010 | 06:56 PM
Spoolin8's Avatar
Experiment: O2 SIM
Obviously there is tons of posts about how there is no O2 simulator that actually works besides masking it with the AP. Well i found one thread in this forum that had this piece mentioned and how 1 member said it worked for him but there was never any follow up or conclusion.
Another item i want to test, but cannot find it on here for the life of me is a O2 spacer that some spamer posted but it had a mini catalytic convertor honeycomb piece built into the spacer and it was 50 bucks and no one wanted to test it and i would like to. So if you know what im talking about please post a link to it.
Im going to get this in next week and ill still be in my new engine break it period but im going to bolt up my exhaust again and test these out and see if we get any results.
Old Mar 8, 2010 | 10:24 AM
T RX8's Avatar
Please let this be the answer to my evil CEL that is consistently taunting me and my MPG and my worries. Btw, gutted cat here so just keep me updated
Old Mar 8, 2010 | 10:28 AM
Yeah i tried the spark plug fouler and it didn't work at all.
Old Mar 13, 2010 | 04:54 PM
Spoolin8's Avatar
Quick update. Finally got one of the L shaped ones in, cost me 30 bucks and just installed it. I average 700 miles a week right now on the car so ill see if/how long it can prevent a CEL.
Old Mar 13, 2010 | 06:33 PM
T RX8's Avatar
Good stuff, how was the install?
Old Mar 13, 2010 | 06:44 PM
hakuna matata!
The CEL you get when you remove the cat has absolutely no effect on gas mileage.
It actually has no effect on any of the cars systems/performance.
The only time that light will get you in trouble is OBD2 inspection.
Old Mar 13, 2010 | 06:50 PM
mr_a2z05's Avatar
i have a friend that put one on his S2000, it worked for him so i guess it would work on the RX8 too.
Old Mar 13, 2010 | 06:56 PM
hakuna matata!
Depends. The AP2's are incredibly more sensitive to emissions then the AP1. On the AP1 you could get away with a simple elbow. The AP2 is still in the same boat as the RX8, there is no for-sure way to get rid of the CEL.
Old Mar 13, 2010 | 08:52 PM
Spoolin8's Avatar
we shall see
Old Mar 14, 2010 | 02:25 PM
Spoolin8's Avatar
Initial results are in. After about 50 miles the CEL came on and it was on for about 25 miles and then shut back off again and im at 100 mile since installing it and is still currently off. Im thinking it kind of works but not enough to keep the CEL off all the time. Keep in mind im not flooring it or even reving it above 4k since im still in my break in period, and it still came on soooo.
Old Mar 14, 2010 | 04:20 PM
T RX8's Avatar
Gotcha, and thanks for the update on the effects of this CEL.(Very very helpful and alot of weight off of my shoulder. ) Just keep us updated... and glad to see its at least kind of working. lol...
Old Mar 14, 2010 | 04:40 PM
Spoolin8's Avatar
I really want to try out the one that has a mini cat built into it. I cannot find it anywhere though. The price of it was a little higher but i dont mind trying it out.
Old Mar 23, 2010 | 05:27 PM
rice_c's Avatar
Is this what you are looking for? http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
Old Mar 23, 2010 | 05:36 PM
$50.00, holy ****. Are all the threads the same?
Old Mar 24, 2010 | 10:46 AM
otakurx's Avatar
Rotorheaded Geek
well that is freakin sweet if it works, funny thing is with a custom header and everything on my car, I'm still not throwing any emissions codes other then the Secondary Air system.
Old Mar 24, 2010 | 11:08 AM
rotarygod's Avatar
One of those worked fine on my Honda. That ecu is a different beast from the RX-8's though. The principle behind it is simple. Move the sensor out of the exhaust stream and then limit the amount of gasses that can get to it by having a small hole connect it to the exhaust. This way some gasses still get there and the ecu still sees them but the amount of lower causing the ecu to think the emissions are lower which means the difference between the front a rear sensor is greater than it is. That works on most cars but again the RX-8 is pretty finicky.
Old May 1, 2010 | 11:05 PM
PlatinumSillk's Avatar
Originally Posted by rice_c
This should theoretically fix the problem we are all having. Has anyone tried this one yet?
Old May 1, 2010 | 11:17 PM
try it let us know..
guessing not so much.
but hey what do i know..
Old Jul 22, 2010 | 03:04 PM
Cf05's Avatar
Not Faster Thn Ryans Spd3
did anyone ever try that cat thing?
Old Jul 22, 2010 | 04:24 PM
paulmasoner's Avatar
Asshole for hire
the mini honeycomb has a chance of doing great, all the other non fouler etc type stuff is a waste of time. if you actually read all those old posts you mentioned, you'd know how the feedback to the PCM works and why the non fouler crap will never work for more than the rare 1%
Old Jul 22, 2010 | 04:27 PM
Cf05's Avatar
yea i was asking about the mini-honeycomb
Old Sep 25, 2010 | 05:35 PM
lostmarine's Avatar
man has there been any word on this mini cat?
