DRL Module Removal?
Old Mar 3, 2010 | 12:24 AM
SirTroops's Avatar
BC DRL Module Removal?
Hey guys!
I've done some Googling and searching on the forum and have concluded that my DRL module is dead.
So before I go out to buy a "new" DRL module, I'd like to know if its possible to just straight connect it and let my headlights run properly without the DRL module?
I don't know much about this and I don't even know if its possible, so just give me some feedback! I'd really appreciate it!
Old Mar 3, 2010 | 12:49 AM
nate340's Avatar
anything is possible but i doubt its done overly easy or i'm sure us Canadians would do this instead of buying new modules. but then again maybe its the fact so few of us have the problem no one has ever looked into it and posted. when the weather gets better i may look into this instead of theory's since i plan on doing some lighting changes this summer.
Old Mar 3, 2010 | 12:55 AM
StealthTL's Avatar
Metatron
Try just leaving it disconnected.
This works on my 'other car' and might just do the trick.....
Either way let us know how it goes.
Old Mar 3, 2010 | 01:15 AM
SirTroops's Avatar
Well apparently its a reccuring issue in RX-8's.. I don't want to buy a new one so I wanna see if this will be a good alternative.
And I'll maybe try that! I don't know how to disconnect it though..
Old Mar 3, 2010 | 12:41 PM
SirTroops's Avatar
Sorry for a double post, but does anyone have a detailed instruction manual PDF or Diagram of how to remove/disconnect the DRL module?
Old Mar 8, 2010 | 02:32 AM
SirTroops's Avatar
WELL everyone, I tried these steps
1. I pulled the DRL fuse but it disabled my highbeams
2. When the DRL fuse is in, I get ONE full highbeam on my driverside headlight rather than the half powered highbeams
3. And I've replaced the stock HIDs and ballasts
Is it possibly the wiring? Or the DRL module itself?
I have yet to find the DRL module itself so if someone could supply me with a picture or something!
Old Mar 9, 2010 | 08:16 PM
MyRxBad's Avatar
Fb's rock!
Sounds like your module is toast.
The module is located behind the glove box.
It's a small blue module (about 3"x3") <- going by memory.
Take out your glove box, get on your back, stick a flashlight up there and have a look for the blue (light blue kind of) module and then unplug it, take out the bolts (1 or 2 of them) and then replace the module.
Unfortunately the module also controls the high beams. so if you feel you need high beams then the module needs to be replaced. If not then unplug it
Old Mar 9, 2010 | 08:24 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
I have the exact same problem, most of the time they are both out, no problem there, the other time one highbeam is on, not alway the same one. Everytime I turn on the car I wonder what I am gonna get. I have a new module on the way. Warranty covered it, was told it wasn't the cheapest little p.o.s.
Do US cars just have a relay or nothing at all? how does that work?
Old Mar 10, 2010 | 12:25 PM
SirTroops's Avatar
Ah.. Yeah I found it! I was told to attempt and unplug it and see if it fixes the issue, but when I did that it also disconnected my Power Windows! Weird eh haha
I'm probably gonna go to Wolfe Mazda here in Chilliwack and see how much a new DRL module it.. Hopefully they don't rip me off.
Old Mar 10, 2010 | 12:27 PM
SirTroops's Avatar
Your vehicle is still under warranty?? Is it cause it didn't hit a certain Kms? Or is it a whole DRL module recall thing?
I heard it was $70 bucks at the Wolfe Mazda dealer in Vancouver
So I don't know, stupid DRL module and Canadian rules..
Old Mar 11, 2010 | 04:23 AM
Chad D.'s Avatar
Spinnnnnnnnnnn
yeah, I have extended warranty until 80000km.
Old Mar 11, 2010 | 10:26 AM
pauleta's Avatar
Is that the price of one of these? $70?
I had mine originally replaced under warranty. Then just over a year after that, it happened again, out of warranty. They wanted over $200 to fix it. I said forget it. I can do it myself. But there's obviously and issue with this module. I don't want it to be a yearly fix.
Old Mar 15, 2010 | 08:02 PM
SirTroops's Avatar
I called all the Mazda dealers and they had them for $131.. What a rip eh?
I'm gonna find one on eBay
Old Mar 16, 2010 | 10:09 PM
(SEED)'s Avatar
(>'o')>
theirs an easier way to disable DRL.
most ford/mazda vehicles use photocells with a low light resistance.
anything from 2-10ohm will work.
simply locate the photocell that feeds its resistance to the module (maybe on the CANbus) so it might not be directly feeding into the module.
replace your photo cell with the resistor and your done, DRL should be disabled.
i can look up the wiring diagrams at work tomorrow if need be and figure out exactly where everything is.
that is all
Old Mar 17, 2010 | 12:01 PM
SirTroops's Avatar
that is all
Well that sounds complicated and a half!! I don't wanna be playing around with resistors and stuff, I'm scared to screw something up lol. But I think I may just be getting a new DRL module, so I was wondering if anyone knows anywhere I can get a cheap module?!
Old Mar 17, 2010 | 12:12 PM
(SEED)'s Avatar
(>'o')>
your photo cell is located somewhere visible to sun light, (dash, center mirror) all the resistor dose is fool the PCM in to thinking its always bright out.
cut off 1 photocell, replace with resistor.
2 wires to be soldered, thats it.
Old Mar 17, 2010 | 12:20 PM
StealthTL's Avatar
Metatron
RX-8s don't have a DRL photocell....
S
Old Mar 17, 2010 | 12:39 PM
TheWulf's Avatar
My 8 looks like a Smurf
I believe the photocell is for "automatic headlights" which we (or at least I) don't have.
The DRL relay simply ensures that you have lights running all the time if you set your switch to OFF.
Old Mar 18, 2010 | 12:02 AM
SirTroops's Avatar
WHOA WHOA WHOA! Simpler terms please! My head is going to explode =P
Old Mar 22, 2010 | 09:57 AM
pauleta's Avatar
Don't forget to change your daytime running lights fluid too :P
I did see the DRL module online for $98 (it quoted the MSRP at $131) at mazda-parts site. I just did a search for part number there (fe0167750). I've never dealt with them just a site I found while searching.
Old Mar 25, 2010 | 08:37 PM
SirTroops's Avatar
HMM.. $98 eh
idk i might just pay the big bucks and get this little POS box.. its quite stupid actually
Old Mar 25, 2010 | 08:59 PM
Mattiji's Avatar
Hey guys i recently installed HIDS in my car and ive tried disconnecting the drl - it does in fact turn off the low beam setting but also disables the power windows, and im certain a few others things - theres gotta be another way unless a CanBus harness maybe>?
Old Mar 25, 2010 | 10:38 PM
nik's Avatar
nik
I was able to "fix" my broken DRL module so that I have high beams and manual headlights.
The problem with my module was one of the 2 relays became defective. my 0$ solution was to remove the relays and replace them with wires to make the appropriate connections to pass through for high beams. Also I had to remove the connection inside the module that detects the position of the handbrake. I have more details on this if someone wants to do the same.
You end up with a car where everything works, and you have manual control of the headlights. (no more DRL)
Old Mar 30, 2010 | 10:28 AM
SirTroops's Avatar
How do you manually change the relay!?
Old Mar 30, 2010 | 11:12 AM
djvinniev77's Avatar
Hey Nik,
yes, some detailed explanation would help. I have the same issue, DRL not running, need the high beams to work, need to fix. I though the high beam bulbs needed replacement, both have been swapped, but still no DRL. Any help would be great!
