Quick rim/tire size question i'm not 100% sure on...
I just want to make sure before I head down to possibly grab a new set of rims. Am I going to have an issue with 18x9.5 with +30 offset all around? Tire widths are 225 and 245 in the rear. I'm pretty sure I'll be good without rubbing but I figured I'd get some expert knowledge...thanks in advance
You do know this is what the Will It Fit thread is for right...? And 18x9.5 +30 is a pretty common fitment, and probably asked on every other page of that thread.
If your running some negative camber in the rear you will be fine. If anything you'll just rub on the fender liner plastic tab, which isnt a big deal.
GK1707
Aug 3, 2015 10:23 PM
Touge
Canada Forum
Jul 28, 2015 09:52 PM
