Racing brake stainless lines & 17" winter/tire rims.
Old Feb 28, 2010 | 06:22 PM
itspec53's Avatar
VA Racing brake stainless lines & 17" winter/tire rims.
I had a set of Racing Brake stainless steel braided lines installed last night. After driving around for a couple of miles today, I checked the clearance of the lines against the inner rim and noticed that when the wheels were turned in either direction, they made contact.
I managed to push the lines further back on the retainer clips which looks to have resolved the clearance issue. But the rubber/plastic coating on the lines looks to have been scored where the contact was made, exposing a small (.5") section of the stainless steel braid.
Question is.. should I worry about these exposed sections? should I wrap in duct tape maybe ?
Old Feb 28, 2010 | 08:49 PM
kersh4w's Avatar
Hit & Run Magnet
normal brake lines arent braided so im going to say you're ok.
however, i'd put a small clamp on that area. the cheap screw type clamp. just to give it some reinforcement.
Old Mar 20, 2010 | 10:40 PM
Can you please post up a picture of your install because I can only conclude that they aren't installed properly. There's no way for my RacingBrake brake lines to rub on a 14" wheel, let alone a 17" wheel. When installed properly everything is contained under the Sport brake rotor diameter which is 12.8". No matter how far in either direction I pull the brake line tight in it does not go outside the rotor diameter. You either have the caliper end and/or the control arm clip connected in the wrong direction.
Old Mar 21, 2010 | 08:12 AM
this is the correct installation arrangement
Attached Thumbnails Racing brake stainless lines & 17" winter/tire rims.-racingbrake-front-brake-line.jpg
Old Mar 22, 2010 | 10:26 PM
TrochoidMagic's Avatar
is adjusting valve lash
that IS the correct install, BUT, it still can get burnt from making U-turns due to tire contact.
when i'm running on my 17x9.5, i cured it by clipping another clamp 2 inches back from the included bracket to the upper arm.
you have to notice that the SS lines are so stiff, it does not flex easily and moves alot when wheels are turned. the oem rubber lines don't have this problem, and bends/flex quite easily.
Old Mar 22, 2010 | 10:28 PM
have this issue addressed immediately. overheating ur brakelines and burning a hole thru it won't be good.
Old Mar 22, 2010 | 11:07 PM
kster's Avatar
I'm also thinking of adding a second clamp as a precaution. What kind of clamp did you use?
Old Mar 23, 2010 | 08:12 AM
I can post pics of the wheel at full lock, still don't agree with the need to do anything other than install them properly
and when are you're wheels ever at full lock except during parking or the odd U-turn? If you can burn a hole in your brake lines doing this then you are doomed for life anyway ....
Old Mar 26, 2010 | 09:55 AM
looked at it again, no way no how will it rub a wheel if installed properly, full steering lock or not
Old Mar 26, 2010 | 11:52 AM
kster's Avatar
Good to know, thanks. I'll double check mine as well to confirm.
UHATEIT
Mar 31, 2019 05:31 PM
BigMikeATL
May 26, 2016 12:31 AM
michaelsk8er
Nov 9, 2015 07:06 AM
EfrainOlivares
Aug 14, 2015 06:17 PM
AussieGray
Jul 16, 2015 03:58 AM
